Brake light fuse keeps blowing | FerrariChat
Discussion in '360/430' started by markoj44, May 2, 2014.
  1. markoj44
    markoj44 Guest
    Feb 8, 2012
    49
    #1 markoj44, May 2, 2014
    im posting about my brake light fuse that keeps blowing.on my 360 f1 spider..i ordered a new brake light switch because that was bad..but has anyone else had this problem....p.s i just had a new exhaust and clutch put in and put about 150 miles on the car before this problem began.....also when i adjust the brake light switch and replace the fuse it works until i turn it off again and then the fuse blows....
  2. markoj44
    markoj44 Guest
    Feb 8, 2012
    49
    i know it doesnt sound like a big deal but it is since it wont let me go into gear without the brake lights working
  3. Macshop6700
    Macshop6700 Rookie
    Feb 8, 2024
    12
    Zaz
    I am having the same issue. Did you figure it out.
  4. GogglesPisano
    GogglesPisano F1 Rookie
    3,227
    East Bay, California
    Joe
    Sounds like a short in the system. Start by checking the bulb and then the wire harness to make sure it isn't pinched somewhere from a recent service or project. Using a multimeter could help identifying a grounded positive line or a short.
    Qavion and Phemes like this.
  5. Macshop6700
    Macshop6700 Rookie
    Feb 8, 2024
    12
    Zaz
    I just made a video on youtube. 2000 ferrari 360 brake lamp switch
  6. hessank
    hessank Formula 3
    1,936
    Canada, Florida
    Fred
    Very informative. Thank you for sharing.
    Here's the quick linky:
    Qavion likes this.
  7. Qavion
    Qavion F1 World Champ
    14,374
    Ian Riddell
    #7 Qavion, May 4, 2024
    In the video you said you disconnected and reconnected the right hand connector behind the seats (6G/11G) and the fuse stopped blowing and then you disconnected and reconnected another connector (1G/1H?) which fed the left hand side tail lights and it also made the fuse stop blowing. This doesn't make any sense to me. Did you mean you disconnected these plugs and the fuse stopped blowing?
  8. Macshop6700
    Macshop6700 Rookie
    Feb 8, 2024
    12
    Zaz
    Yes, thats exactly what happened. Just as a precaution i replaced all the bulbs to. Its not blowing anymore.
    Qavion likes this.
