430 - BRAKE light intermittent flashing at WOT | FerrariChat
430 BRAKE light intermittent flashing at WOT
Discussion in '360/430' started by VAF84, Dec 27, 2020.
  1. VAF84
    VAF84 Formula 3
    Jul 23, 2016
    2,278
    Central Texas
    I did a little searching on my issue, and have already checked the brake fluid based on a similar thread. It's nice and full, and also was recently flushed at Ferrari of Austin.
    The last two times I went to stretch out the car and get the fluids flowing (also don't want the ECU to adapt to granny driving :D)I had the red BRAKE light briefly flicker, typically towards the top half of third, before shifting to fourth (F1) at 90% throttle in sport mode. This is very recent. Doesn't flicker at all during normal driving, in fact come to think of it, the light didn't flicker in any other situation except straight line launches. The hand brake was all the way down. Checked a few times to make sure. The car otherwise drives as normal, doesn't feel like the brake is catching or anything like that.
    Anyone have experience with this? FOA told me at the post track day inspection that brakes were still good, but getting low. Haven't driven it much since. Will worn out pads trigger the light?
  2. Qavion
    Qavion F1 World Champ
    14,233
    Ian Riddell
    Typically, Ferrari brake lights will illuminate for low pad material (front, with rear optional) and low brake fluid. (!) or BRAKE.
    The Park Brake has a different symbol. (P) or PARK
    VAF84 likes this.
  3. VAF84
    VAF84 Formula 3
    Jul 23, 2016
    2,278
    Central Texas
    Thanks Ian, that's reassuring, and in line with the most likely scenario. Looks like brakes are next on my to do list.
    Qavion likes this.
  4. 24000rpm
    24000rpm F1 Rookie
    your car is a stick right? If so, it is because your brake fluid leaked so much that your brake fluid level sensor is giving a warning.
    VAF84 likes this.
  5. Qavion
    14,233
    Ian Riddell
    Already eliminated as a cause....
    VAF84 likes this.
  6. 24000rpm
    24000rpm F1 Rookie
    would you elaborate on how that was eliminated? What was tested or done?
  7. Qavion
    14,233
    Ian Riddell
    You seemed to be suggesting that low brake fluid level was causing the brake warning light. Since the brake fluid level was visually checked ok, it can't be the level of the brake fluid causing the problem.
    It could, however, be a faulty brake fluid level sensor or sensor wiring (short to earth). I assume Ferrari designed their (float?) sensors to make reliable measurements under high accelerative forces i.e. the fluid doesn't shift to one part of the reservoir activating the switch. I wonder if the system has a timer to prevent momentary low levels trigging the light?
    Since the indications are intermittent, it's going to be difficult to faultfind. Perhaps for a short test period, you could remove the plug on the fluid level sensor to see if you still get the fault light under hard acceleration?
    VAF84 likes this.
  8. Qavion
    14,233
    Ian Riddell
    Another line of thought. On 360's is the brake pad wear indication normally only triggered when the brakes are applied?
  9. 24000rpm
    24000rpm F1 Rookie
    Yes, just like you described, it could. When the car is under acceleration, the surface of the brake fluid will change from flat to a slope. The edge of the slope, while well above the sensor when the car is under no acceleration, could fall lower than the sensor when under acceleration, ergo the light. Not saying that your car is this case, but it is a possibility that I've encountered twice in my stick 360.
    No, it doesn't have a timer, so each momentary low fluid level will result in a flicker of the brake warning.
    I think the test you can do is to fill up the brake fluid to such a point that is over what the wsm recommended. If you still get a brake light, that means what I described isn't your case.
    VAF84 and Qavion like this.
  10. 24000rpm
    24000rpm F1 Rookie
    #10 24000rpm, Dec 29, 2020
    On my 360 , I've a test about a year ago that I cut all the brake pad wires to the ecu. The brake warning will not show in my test.
    also on my 360, also a few years ago, I was doing some track time, in which I totally destroyed my pads, worn to about 1mm or less left and all of the brake pads are cracked , too. There's also no brake warning light in the dash. Just my personal observation. I was surprised, too, at the moment, that there's no warning.
  11. Qavion
    14,233
    Ian Riddell
    Good to know. This is the same on the 355. Disconnecting the brake pad wiring removes any chance of the warning light circuit receiving an earth via the pad sensors. If no luck disconnecting the plug on the fluid level sensor, disconnect the brake pad wires one at a time.
    VAF84 likes this.
  12. VAF84
    VAF84 Formula 3
    Jul 23, 2016
    2,278
    Central Texas
    It's the F1 transmission.
    Once I get some more time to do some other tests I'll update. It's already back in it's car jacket; but I try to schedule a run every two weeks. Thanks for the tips!
    Qavion likes this.
  13. Qavion
    14,233
    Ian Riddell
    Perhaps broken pads also break the sense wires. Were the pads OEM? (Did they have wear sensors?)
    VAF84 likes this.
  14. 24000rpm
    24000rpm F1 Rookie
    yes, OEM. hmmm.... didn't remember if I broke the sensor
    VAF84 likes this.
  15. BrettC
    BrettC Formula 3
    Aug 13, 2012
    2,113
    Calif
    Brett
    pad sensors are close enough to worn that vibration is causing a wire to hit ground. Mine used to do that and now they don't. I cut them off. Ha! With after market pads they also can get loose causing the same issue. drove me nuts having that light flash so I took them off.
  16. VAF84
    VAF84 Formula 3
    Jul 23, 2016
    2,278
    Central Texas
    Resurrecting the thread here as I missed the last three responses.
    The tech looking at it needs more time to resolve, but more than likely I will do a pad replacement. @BrettC comment makes a lot of sense. Ferrari of Austin told me my pads were getting low and needed replacement soon (not right away). The other place I took it to says there’s still life left. However, it may be that the OEM pads have a higher safety threshold, in the sense that they will flag a warning with more wear remaining than others might. In other words, not allowing you to get dangerously low on brake pad. My next step will be having someone replace the pads once I get situated at my next location.
  17. Alex HH
    Alex HH Karting
    Dec 11, 2021
    87
    Zhuhai (China)
    Alexis H
    Hey there did you figure out what happened ? My spider started doing the same , Xmas break failure warning sparkling , reported as b100C when reading codes but I don’t feel any difference on the brakes performance .
  18. Qavion
    14,233
    Ian Riddell
    So the brake light is flashing only during hard acceleration?
    "Xmas break failure warning sparkling" doesn't tell us much.
  19. Alex HH
    Alex HH Karting
    Dec 11, 2021
    87
    Zhuhai (China)
    Alexis H
    Haha sorry that’s true.
    It seems to show more under acceleration, but sometimes comes in and out even when at idle. Sometimes stays on for a while the when i take off again it will go away.
    Sometimes flickers, usually under acceleration.
    It seems really random and hard to see a pattern (also doesn’t help to monitor that while driving)
    I had my clutch changed recently after my car went nuts at a toll station (very hot day). I was idling in N waiting for my turn and when switched to 1st it wouldn’t engage the gear, brake light flashing and clutch slipping like crazy. After a few restarts I managed to drag the car into 2nd and drove it all the way to a garage nearby. We checked codes and nothing was showing, car went back to normal only to struggle again 1h later. Anyway car was 40k and some signs of clutch wear, so I decided to go for a new clutch. Long story short, first time I saw that brake light flash was during that incident. Didn’t show after new clutch (I wore it in for 300-400km) and suddenly noticed the light flickering about 1000km after new clutch in.
    doesn’t seem to affect braking performance (I tried hard braking, different situations etc and doesn’t fade or anything )
    I checked brake fluid, it’s clear and levels are right.
    Changed my brake pads to “blue stuff” ones about 4000km ago
    Qavion likes this.
  20. Qavion
    14,233
    Ian Riddell
    Try disconnecting the connector on the brake fluid reservoir. If that doesn’t work, there’s probably something wrong with the brake pad sensors (or a wiring issue). The only other thing that can put the light on is an ABS issue, but that would put the ABS light on simultaneously.
  21. Alex HH
    Alex HH Karting
    Dec 11, 2021
    87
    Zhuhai (China)
    Alexis H
    Hey there, I finally found out the issue (and feel a bit like an idiot xD)
    I was convinced I changed my pads (front and back) 4000 km ago, but it was only the front ones.
    So I grabbed a set of rear EBC, swapped to new ones, resurfaced discs, etc... light disappeared
    Sometimes you gotta look at the most logical answer :rolleyes:
    Qavion likes this.
