Brake lights not working on 348 | FerrariChat
Discussion in '348/355' started by vdettore, Mar 7, 2018.
  1. vdettore
    vdettore Formula Junior
    Mar 3, 2017
    353
    Georgia Coast
    Vince
    On a trip and just found out brake lights are not working. They were working when I checked a few weeks ago. Where should I start?
    Of course I don’t have a manual with me can anyone send a picture of the fuse box in which fuse it might be? Thanks so much
    Thanks for help.
  2. vdettore
    Mar 3, 2017
    353
    Georgia Coast
    Vince
    Wipers work so I don’t think it it the fuse, because I believe the wipers and stop lights are on same fuse.
    Any other ideas?
  3. Qavion
    Qavion F1 World Champ
    14,436
    Ian Riddell
    #3 Qavion, Mar 7, 2018
    Faulty brake pedal switch? Try cleaning it. Note that this switch has an input to the ABS, but I haven't looked into what effect it has on the system.
    (EDIT) Is the electrical connector on the switch still plugged in?
  4. vdettore
    Mar 3, 2017
    353
    Georgia Coast
    Vince
    Thanks, where is the brake pedal switch ?
  5. LorenzoOO
    LorenzoOO Formula Junior
    Sep 21, 2017
    832
    Italia, US NE
    Lorenzo LaMattina
  6. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    I never looked for the brake pedal switch on my Ex 348. In the old days (most cars) it's a simple contact switch that gets triggered by the pedal and arm moving forward, contacting it. Thus look up and down the back side of the pedal shaft/arm. And I assume you have checked that it's not just bad bulbs?
  7. vdettore
    Mar 3, 2017
    353
    Georgia Coast
    Vince
    Thanks I’ll look for it. No I haven’t check d the bulbs yet but will as well. Are the rear bulbs easy to access ?Thanks again.
  8. Qavion
    14,436
    Ian Riddell
    Yes, just remove the light assembly covers from inside the engine compartment. Then unscrew the lamp holders (bayonette type). When changing the lamps, look for corrosion on the lamp holders and clean as required.
    Do you have a digital multimeter for basic electrical checks?
  9. vdettore
    Mar 3, 2017
    353
    Georgia Coast
    Vince
    I’ll pick one up. We just got to Amelia Island for the Concours so hopefully it’s just the bulbs.
    Thanks!
  10. vdettore
    Mar 3, 2017
    353
    Georgia Coast
    Vince
  11. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    Unfortunately, the brake lights have their fuse and relay in the passenger side footwell fuse box (right figure) and not under the front hood (left figure). Fuse No. 5 is for the brake lights. Relay B is for external lights. I'd probably go with the brake switch first, then look for a grounding problem at the lamps. However, could be simply the rear tail light is shot. See if your tail lights work when the headlight/fog lamps are illuminated. Might give you a clue about the lamp itself.
  12. Qavion
    14,436
    Ian Riddell
    His wipers are working, so it won't be the relays or fuse.
    F348 Lights Wiring Diagram
