Buy
brake lights won't go off
Discussion in 'Technical Q&A' started by tifosi, May 23, 2004.
  1. tifosi
    tifosi F1 Veteran
    Sep 5, 2001
    5,382
    texas
    Tom D
    Following some other electical problems I was having with my 86 3.2 mondial I replaced the fuse box - all problems were fixed. Yesterday when I pulled in the garage I noticed the warning light for the brake lights would come on when I applied the brakes - this would normally mean a light was out, I then noticed the brake lights are on all the time, applying the brakes does not change anything other than cause the waring light to come on in the center consol. any thoughts on where to start
  3. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,366
    NY
    Check the brake light switch up near the brake peddle. Sounds like it either backed out of adjustment or it is broken.
  4. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Agree would check the brake light switch first, then the fusebox for a stuck relay.
    Good luck and best regards
    rt
  5. ShanB
    ShanB Formula Junior
    Jul 9, 2003
    547
    Tejas/Europe/Desert
    shanb
    I too vote for the brake light switch.
  6. ferrarifixer
    ferrarifixer F1 Veteran
    8,520
    Melbourne
    Phil Hughes
    Maybe you should call the other Mondial owner who started another thread.... whose lights won't come on. Between you two, you'll nail it in minutes!
  8. tifosi
    tifosi F1 Veteran
    Sep 5, 2001
    5,382
    texas
    Tom D
    thanks guys, I will advise the results
  9. ian_jory
    ian_jory Karting
    Apr 13, 2004
    52
    Ian
    Hi Tom,
    Check my reply on the other thread I started about the brake lights not working - I found the fault in the switch and I have explained what I found inside the switch when I dismantled it. It could have a bearing on your problem.
    Ian
  10. Vivaldi
    Vivaldi Karting
    Aug 1, 2001
    83
    SoCal
    Alex Vivaldi
    Tom - check my post on the other thread re. replacing the switch. Best of luck!
