Brake Lights | FerrariChat
Brake Lights
Discussion in '348/355' started by stevew3765, Feb 14, 2014.
  1. stevew3765
    stevew3765 Formula Junior
    Oct 27, 2012
    716
    Tulsa, Oklahoma USA
    Steve Wool
    Hello dear friends! Its going to be a NICE weekend here in Tulsa. But, I have been stricken with a brake light problem that could hamper my being able to go out( and be safe anyway). So, I call upon you for help. It has been my experience that no brake lights are 1. Bulb or bulbs out. 2. Fuses and or relays. So, considering the fact that I have blinkers on all four sides, running lights on all four sides. Tail lights and headlights all good. Just no break lights at night or day. Any idea where to go from there? And help would be greatly appreciated. Thanks and have a great weekend everyone!!!!
  2. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    Brake light switch. Or a very rare coincidence of both tail lights having their brake bulbs burned out simultaneously - happens.
  3. Ferrari Fanatic
    Ferrari Fanatic Formula 3
    Apr 2, 2003
    1,317
    SoCal
    Same thing happened on my 355....It first checked my fuse, did some simple checks with my VOM Meter and found it was my switch.
    The switch is in the cockpit down by the brake pedai.
    I ordered a switch from Racambi for less than 30 bux and in ten minutes I replaced it and was good to go.
  4. stevew3765
    Oct 27, 2012
    716
    Tulsa, Oklahoma USA
    Steve Wool
    #4 stevew3765, Feb 15, 2014
    I took my switch out and disassembled it. Here is what I found. I broken spring. Even though it was plunging fine Idk. I will order a switch and see if that is it...
  5. vvassallo
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    Generally the simplest answer is the right one. I try not to over think things just because it is a Ferrari. It's just a car after all. ;)
