Brake master cylinder change / booster question | FerrariChat
Discussion in '308/328' started by jaisharma, Aug 30, 2021.
  1. jaisharma
    jaisharma Karting
    Aug 4, 2011
    215
    South east, UK
    Jai Sharma
    Hi,I had what seems to me like master cylinder seal failure on my early 308. The symptoms were that the brake pedal went to the floor, then in an "emergency pump" there was a little retardation but not much. Quite "exciting" coming up to a braking area on a circuit....
    Master cylinder seals were done about 15 years ago, not by me but in my ownership.
    Anyhow, I've taken the master cylinder off and bought a replacement, and also removed the reservoir to re-use that.
    My question is about the lever that comes out of the brake booster into the master cylinder. It basically just came out too, though not fully as there is a seal. I can put it back in the booster and it seems to locate centrally, but is that normal? I guess it can't go anywhere when the master cylinder is back in place, but just thought I'd check.
    I'd add the booster was working fine.
    Many thanks!
  2. kiwiokie
    kiwiokie Formula 3
    Aug 19, 2013
    1,539
    Tulsa, OK
    John McDermott
    Yes it is not threaded or fixed into the booster.
  3. jaisharma
    jaisharma Karting
    Aug 4, 2011
    215
    South east, UK
    Jai Sharma
    Many thanks
  4. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,640
    Toronto / SoCal
    Rob C.
    When replacing the master cylinder be 100% sure to check the plunger to booster clearance. Also you will need to bench bleed the master. Here are some videos I made on the subject:
    thorn and miketuason like this.
  5. jaisharma
    jaisharma Karting
    Aug 4, 2011
    215
    South east, UK
    Jai Sharma
    Thank you very much for taking the time to post that (and to make the videos), really helpful and I appreciate it.
    Nuvolari likes this.
