Brake master cylinder piping | FerrariChat
Discussion in '308/328' started by mixedgas, Jul 19, 2025.
  1. mixedgas
    mixedgas Formula Junior
    275
    Ramona, CA
    Gents, I'm reinstalling my master cylinder/booster (after a 7 month rebuild...) and I failed to mark the orientation of the two brake lines which connect to the master cylinder. One line feeds the front brakes, and one the rear brakes (I believe). Can anyone tell me about the driver vs. passenger side ports on the master cylinder should feed the front vs. rear brake circuits? (car us left hand drive)
    Thanks!
  2. Imatk
    Imatk Formula Junior
    May 6, 2007
    773
    I'm guessing you ran new lines? On mine there would be no way to cross them up... not enough length on the pipe.
    Sorry can't help otherwise.
    mixedgas likes this.
  3. mixedgas
    275
    Ramona, CA
    Thanks for the response, you are correct, they only fit one way. Thanks!
    Imatk likes this.
  4. fatbillybob
    Aug 10, 2002
    29,057
    socal
    I see the mc installed dry. It’s unlikely you will be able to get working brakes in that condition. Typical easy install process is to have the lines all ready. You bench bleed the Mc plugging the outlets then mount and remove plugs and attach lines. Then you bleed the system
  5. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,238
    CT
    John Kreskovsky
  6. mixedgas
    275
    Ramona, CA
    Thanks for the thoughts and agree I decided to roll the dice on no bench bleed - maybe I'll be kicking myself but I'm going at bleed with a motive pressure bleeder and using an assistant. The entire system is dry so I expect significant effort getting pedal.
    I always forget that the 308 owners manual has so much good info but worth noting that diagram is inconsistent with how my 308 was plumbed from factory (diff pressure valve is shown reversed from actual - left side feeds rear, not right) but I tend to agree it doesnt really matter provided front and rear are kept as separate circuits
  7. Imatk
    May 6, 2007
    773
    You'll need to bench bleed it, but you won't be able to actually do that "on the bench" you need to get one of the bench bleeder tools you can run while it's connected on the car.
