Brake pad thickness?... | FerrariChat
Discussion in '458 Italia/488/F8' started by MaxxSpeed1964, Jun 22, 2011.
  1. MaxxSpeed1964
    MaxxSpeed1964 Rookie
    Jun 22, 2011
    1
    Rancho Palos Verdes
    Jim Soldera
    Can someone please tell me the material thickness of a new front brake pad for the 458?...
  2. vm3
    vm3 Formula Junior
    Apr 12, 2007
    728
    California
    10 mm
  3. tazandjan
    39,176
    Jim- Welcome to FChat. How many millimeters of pad do you have remaining?
    Taz
    Terry Phillips
  4. action-ant
    action-ant Karting
    Nov 16, 2015
    179
    San Francisco, CA
    Anthony
    Bringing this thread back to life. Recently had my car brought in for the airbag recall, dealer wrote 6mm front pad thickness and 4mm rear pad thickness, which I thought was odd because I measured 7mm front and 8mm rear to the backing plate. Anyways, what's the consensus of when the pads should be replaced?
  5. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    Depends on use and risk tolerance. They can last a long time with moderate use, but a track day will go through them way faster. If they get too low, you risk rotor damage, and the replacements are very pricey. I’d say 2-3mm is where I’d consider changing them if I only drove the car on the street.
  6. LCW
    LCW Karting
    Dec 29, 2016
    94
    South Florida
    Aren’t there sensors that would tell you when it’s time?
  7. action-ant
    action-ant Karting
    Nov 16, 2015
    179
    San Francisco, CA
    Anthony
    Yea there are wear sensors, and I think if the pads were replaced before the sensors touched the rotor, the sensors could be re-used? I think 7-8mm should be fine for street driving, and *maybe* one more track day (approx 90-100 track miles). In any case, I'll start looking at pad options since they will need to be replaced eventually. Has anyone gotten any feedback on other pads besides the stock brembo's?
    Ant
