Brake Pads Front & Rear for 612 | FerrariChat
Discussion in '612/599' started by icelander47, Oct 20, 2018.
  1. icelander47
    icelander47 Karting
    Sep 12, 2012
    142
    What are people buying for brake pads for the 612? I need to replace mine as they are down to 5mm. Might as well do all four at once.
    I saw something about the WRX pads, yet I have no idea which ones or which rears.
    Help please
  2. ttforcefed
    ttforcefed F1 World Champ
    19,278
    safe to assume ceramics? i plan on going with oem when i need them for my FF
  3. icelander47
    icelander47 Karting
    Sep 12, 2012
    142
    No, mine are steel.
  4. ttforcefed
    19,278
    ah. i use oem on all my steel ferraris. not sure if going aftermarket is worth the brain damage?
  5. icelander47
    icelander47 Karting
    Sep 12, 2012
    142
    Is there a brembo part number to buy the parts directly vs paying the 500% markup for the ferrari box?
  6. 360Marnix
    360Marnix Formula Junior
    Jan 4, 2017
    491
    Holland
    I am pretty sure it is mentioned in the owners manual! (including part number)
    Verstuurd vanaf mijn G3121 met Tapatalk
  7. icelander47
    icelander47 Karting
    Sep 12, 2012
    142
    I have the Ferrari numbers. I am looking for the brembo numbers
  8. 360Marnix
    Jan 4, 2017
    491
    Holland
    Brembo numbers, rear: 107.9706.10
    Front: 107.8560.43
  9. icelander47
    icelander47 Karting
    Sep 12, 2012
    142
    Just got the front and rears from eurospares for $459 delivered. Not bad at all
    jorge da cruz likes this.
  10. ttforcefed
    19,278
    versus what from the dealer?
  11. brogenville
    brogenville Formula 3
    2,309
    Robin
    There’s loads of different cars that use the same Brembo callipers, so it’s not difficult to get main manufacturer OEM pads at a fraction of the cost of F parts. Just make sure you get the version that has the slot at the top for the wear sensor- a lot of cars use the same pad pattern but don’t have a wear sensor.
    One example I found was certain models of VW Toureg which uses the same pads as the 612, and loads of Ferrari’s and Maseratis for that matter.
    Seems like a sensible way to go, unless you particularly want to pay an extra few hundred quid for a small cardboard box with little horses drawn on it.
  12. randkin
    randkin Formula 3
    1,497
    Somis, CA
    Randy
    Are these the numbers for the CCB break pads for the OTO cars or the standard break pads for the Gen 1 612s?
  13. 360Marnix
    Jan 4, 2017
    491
    Holland
    Standard steel brakes
  14. randkin
    randkin Formula 3
    1,497
    Somis, CA
    Randy
    Thanks, do you happen to know where to get the Bremo numbers for the CCB brake pads for the OTO cars?
  15. 360Marnix
    Jan 4, 2017
    491
    Holland
    No I can not find those numbers. I don't know if those excist in the aftermarket.
