458 - Brake pedal sinks to floor, no loss of fluid..? | FerrariChat
458 Brake pedal sinks to floor, no loss of fluid..?
Discussion in '458 Italia/488/F8' started by 1cerberus4u, Jun 11, 2025.
  1. 1cerberus4u
    1cerberus4u Karting
    184
    Bedford NH
    andy sanborn
    Hey All;
    So, my 458 has a brake pedal issue that I do not think is the recall issue (could be wrong though). Pedal is very very soft and sinks to the floor, with key on and with the car running. Obviously I have stopped driving the car but it would be great to fix.
    My first thought is the master cylinder has gone bad, but with only 10k miles on the car?? Seems strange.
    Obviously if it was the booster, the pedal would be rock hard. Here, no,
    I thought it might be the recall, but the fluid reservoir is full, so its not leaking....
    Anyone confirm my thought or have a different view?
  2. fatbillybob
    Aug 10, 2002
    28,989
    socal
    With Ferraris it is usually age not miles that things go bad. The newest 458 is 10 y/o so yeah a MC could die in 10kmiles. If no other maintenance has been done because so low miles the entire brake system needs to be gone through. At age 10 you should have flushed the system somewhere between 5-10 times already. Flushing keeps the system from absorbing water and producing particulates and precipitates that damage seals that kills your MC or shorten's its life.
    mdrums likes this.
  3. 1cerberus4u
    1cerberus4u Karting
    184
    Bedford NH
    andy sanborn
    Thanks Billybob. So you too are guessing a new Master? Am i correct to assume its a straight swap out (after bench beading it)?
  4. mikey64
    mikey64 Formula Junior
    570
    TN
    mikey
    Have you tried just bleeding the brakes?
    Can you build any pressure by pumping the pedal?
    flash32 likes this.
  5. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,900
    Central NJ
    Dominick
    +1
    And to add to the above post was anything that preceded it
  6. 1cerberus4u
    1cerberus4u Karting
    184
    Bedford NH
    andy sanborn
    Hey Mike, I have not bled the brakes yet as its clearly not an air in the lines thing. Pedal is not spongy, nor does it "pump up" as some pedals will do. I could but I'm pretty confident its not air, but something wrong mechanically
  7. 1cerberus4u
    1cerberus4u Karting
    184
    Bedford NH
    andy sanborn
    Flash, nope, nothing. Went to start the car, stepped on the pedal and said to myself, wow, that pedal just sank to the floor, but it comes back up.... Started the car, went for a drive and while the pedal comes back up, pressing the brakes, its just goes down to the floor.
    Thinking it was the recall thing (which I have not done) I checked the reservoir and that remains full
  8. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,900
    Central NJ
    Dominick
    Interesting
  9. fatbillybob
    Aug 10, 2002
    28,989
    socal
    Yes that or rebuild with new seals...but...everyone tries a system bleed first just to make sure. It makes no sense that a working system would somehow get air in there to cause a spongy pedal, unless very porly maintained, but we do that step first anyway. When there are extremes say a racecar with marginal brakes run hard and put away wet you can get the spongy pedal the next time you just move the car around or do a short paddock drive. That happens when you heat boil the fluid locally and that boils off any absorbed water and that puts air in the system. I can't think of a time that happened to a legally driven street car. But go through the steps. A bleed takes you 10 mins or under an hour if you have to take the wheels off for access.
  10. Snapshift
    Snapshift Formula Junior
    924
    Centralia IL
    Lyle D. Pahnke
    Seems there is minimal hydraulic pressure developed by the master cylinder. If booster is ok, and nothing changes after a bleed, I'd replace the master cylinder This is indicative of a failed master cylinder as everyone has stated. There is internal leakage past the master cyl pistons. Probably sat for years with low fluid in it, rusted/scored master cyl walls, and someone just topped off reservoir with fresh fluid. IMHO.
    1cerberus4u likes this.
  11. mikey64
    570
    TN
    mikey
    Bleeding is free. Eliminate the possibility that you have air in the system which can come from an over active abs or stability control if the car is overdriven.
    Worn pads also can contribute to a spongy pedal as the pistons are further out and more fluid is required. As mentioned someone else might have added fluid.
    1cerberus4u, Challenge and Snapshift like this.
  12. Snapshift
    924
    Centralia IL
    Lyle D. Pahnke
    As I stated above, "after bleeding and checking booster".... What we don't know is the maintence history, pad history, tracking details etc. It sounds like its a garage queen. What would be helpful to know is there any braking effect at all when stopping? if none or little,.pads, or master cyl would be my bet.
    mdrums likes this.
  13. Hopeful
    Hopeful Karting
    May 31, 2019
    156
    Vero Beach, FL
    Tony M.
    The master cylinder went out on my 488 after about 5K miles, so not so strange. And the symptom initially was a pedal that went to the floor with very little braking ability followed shortly thereafter by no braking ability whatsoever as it dumped all the fluid. I suspect it would not take much of a leak to ruin the master cylinder seal.
  14. 1cerberus4u
    1cerberus4u Karting
    184
    Bedford NH
    andy sanborn
    Yes I can build some pressure and the car stops, but its a bunch of press press press...
  15. 1cerberus4u
    1cerberus4u Karting
    184
    Bedford NH
    andy sanborn
    Thanks Hopeful. No leaking for me, but clearly something is amiss........ Eurospares has new MC's with booster for under 500 bucks.. Guess I'm gonna try it
  16. 1cerberus4u
    1cerberus4u Karting
    184
    Bedford NH
    andy sanborn
    Snap, the car has 13k miles on it, so I do drive it. That said I'm in the North East, so it gets put away for the winter... I can pump it up and stop the car, and the pedal stays up, just little to no pressure behind the pedal
  17. 1cerberus4u
    1cerberus4u Karting
    184
    Bedford NH
    andy sanborn
    Fatbob, the car has not been tracked so I know its not from boiling fluid... Gonna bleed first and see..
    pdxjim488 likes this.
  18. Snapshift
    924
    Centralia IL
    Lyle D. Pahnke
    #18 Snapshift, Jun 23, 2025
    Has the brake recall been done on it? There was a period of time that the brake reservoir cap was not ventilating properly and starving the master cylinder of brake fluid, If I understand the issue properly. The dealer replaced the cap with another type that had a better ventilation setup in it and adjusted some software to indicate low brake fluid earlier.
    Have you bled the brake system yet? There could be air in the system that gives the spongy pedal. IF so, and it still is symptomatic, it is an internal leak in the master cylinder. Ill bet the new booster and master cyl will solve your problem if there are no external leaks in the system. GL.
  19. dohais
    dohais Rookie
    Dec 24, 2024
    21
    Russia
    replace master cylinder with new reservoir fluid cap. get some good brake fluid and do brake bleeding using pump at least 2.2 bar pressure and by using official dealer tool or texa to bleed abs system. helped with mine 488.
  20. LVP488
    LVP488 F1 Veteran
    Jan 21, 2017
    5,879
    France
    The brake recall was to address (in theory) a booster issue caused by the fluid leaking into the booster; so the symptom of the issue was not a spongy pedal but exactly the opposite (hard pedal, so no braking with normal pressure applied), since there was no booster working anymore.
    Snapshift likes this.
