Brake proportioning valve | FerrariChat
Discussion in '308/328' started by gansevoort, Feb 23, 2024.
  1. gansevoort
    gansevoort Rookie
    Sep 28, 2012
    21
    Sarasota FL
    Patrick M.
    I would like to know was is the easiest way to access the brake proportioning valve on a 1979 308 in order to clean the electrical connection .
    Thank you for your help .
    P.
  2. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,638
    Toronto / SoCal
    Rob C.
    Straight from underneath. There should be an access panel right behind where the battery is bolted to the chassis. Lots of cars have this panel missing but you can access the valve easiest from this angle.
  3. gansevoort
    gansevoort Rookie
    Sep 28, 2012
    21
    Sarasota FL
    Patrick M.
    Thank you !
  4. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,741
    The twilight zone
    Is that the proportioning valve? My QV manual calls it "device for light signal or differential oil pressure in the brake circuits" and then shows another item in the rear brake lines near the rear called "pressure regulator".....but the parts manual doesn't show the pressure regulator and I'm pretty sure my car matched the parts book diagram not the diagram in the manual.
  5. Dockboy
    Dockboy Formula Junior
    602
    Maryland
  6. Steve Magnusson
    26,806
    What "QV Manual" print number?
  7. Rifledriver
    37,100
    The Mondial QV manual says that.
  8. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,741
    The twilight zone
  9. Ehamilton
    Ehamilton F1 Rookie
    2,638
    Durham, NC; USA
    Eric Hamilton
    Just looking at the guts of disassembled units (in the threads linked from this one) it surely looks like a differential pressure switch and not a proportioning valve.
  10. Dockboy
    602
    Maryland
    #10 Dockboy, Feb 23, 2024
    It is just a differential pressure switch. The "proportioning" happens with the bias valve. There is a bias valve in the rear circuit after the switch that limits the rear circuit pressure the harder the brakes are applied.
    On my '77, the bias valve is located in the front by the switch, not in the rear of the car. See picture below. Differential pressure switch on the left, bias valve on the right.
    Sergio Tavares likes this.
  11. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,741
    The twilight zone
    Interesting, definitely a different part than was in my QV...maybe they dropped it with the QV?
  12. Dockboy
    602
    Maryland
    I'm confusing things a little by calling them different names than the Parts book.
    You are right...what I am calling the pressure differential switch is the "Brake Failure Indicator" and the bias valve is the "Pressure Regulator".
  13. Steve Magnusson
    26,806
    What "parts manual" are you referring to here? Are you mixing 308QV and Mondial QV? The "pressure regulator" shown in the Modial8/QV WSM does seem to be shown in the Mondial QV parts manual:
    https://www.ferrariparts.co.uk/diagram/ferrari/mondial-qv-coupe-cabriolet/029-brake-system-(valid-only-for-lhd-up-to-chassis-no-43011)
    https://www.ferrariparts.co.uk/diagram/ferrari/mondial-qv-coupe-cabriolet/030-brake-system-(valid-for-rhd-for-lhd-from-chassis-no-43013)
  14. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,741
    The twilight zone
    Absolutely. I have 3 books:
    Mondial QV shop manual
    308 QV/328 shop manual (which is really just a supplement showing what changed)
    US QV parts book
    So clearly not an actual complete set. The point is though the 308QV parts book doesn't show a proportioning valve and I didn't find one when I was pulling out the factory stuff to do the brake mods so I just assumed 30-8s don't have them, but there is a valve in the pic of the 77 308 setup. Now I wonder when it went away and why they made that change? or if the new style "failure detector" included a proportioning valve....I might go take mine apart and look.
  15. Steve Magnusson
    26,806
    1978 ;) (on 308)
  16. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,741
    The twilight zone
    Thanks. It seems such an odd design choice for a street car that it just never occurred to me before this thread that they had done that.
    .......I guess they figured that since most cars were GTSs its a safe bet most don't drive in the rain and will never notice or care about longer stopping distances on wet roads where no proportioning valve means the car is giving up about 15-25% of possible braking :oops:
