348 - Brake Pump Runs before startup but won't run AFTER startup! | Page 2 | FerrariChat
348 Brake Pump Runs before startup but won't run AFTER startup!
Discussion in '348/355' started by seabass23, Jun 7, 2023.
  1. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,553
    Jeff
    Hi Matt can I just check a few things with you....?
    If you remove the brake fluid reservoir cap in the frunk when you switch on the ignition to the 1st setting can you see the fluid go down (as the accumulator is being charged with fluid)?
    NB. I had been messing with the brakes already so it did it quite quickly after switch on but if you have not used the car for a day or 2 this can take about 30 seconds or so as the accumulator loses pressure and the reservoir refills with the fluid.
    As above if you have your foot already pressing the brake fluid before switching on do you hear the pump buzzing and then feel a vibration in your foot on the brake followed by a slight drop in the pedal just as the ABS light goes out?
    And view of just the pedals - you should feel a slight tremor in the pedal as it runs the test followed by the pedal relaxing slightly
    Have you thought about just buying a new orange relay to 100% rule it out?
    Is the test fuse (my UK car is shown so may be the other way round but it's the 5amp one above the relay with a white spot) NOT in - pic here shows it in place but that is not the norm - should be removed unless testing.
    Did you know that if you have the test fuse in as per pic above you read flashes on the dash that tell you of any stored fault codes?
    Have you definitely got a 348/355 ABS CPU installed and not one from another car (people do do that)?
    Just so I understand right once you've started the car (and the engine running) but not driven anywhere the abs and brake failure light both extinguish then after driving and breaking a couple of times the brake fail (or is it the ABS light) comes on? Or both?
    Might be worth posting a video of ypur startup sequence of lights and also a pic of the lights you get when the problem occurs.
    Qavion likes this.
  2. Qavion
    Qavion F1 World Champ
    14,605
    Ian Riddell
    I just bought a used USA Brake Light Test/Seat Belt&Door Buzzer Module for U$27. I'll run some tests on it to see if is more than just a relay (brake-wise).
    If it's easy to get inside, I'll take some photos of the internals.
    I didn't realise it was fitted to so many different Ferraris... 328's, 348's, 355's, Testarossa...
  3. Qavion
    14,605
    Ian Riddell
    Checking volts at the orange relay socket (with the relay pulled) should prove that the fault is elsewhere. The relays are not cheap ... USD90 + P&H.
  4. seabass23
    seabass23 Karting
    Nov 6, 2016
    156
    St Albert, Alberta
    Matt
    #29 seabass23, Jun 9, 2023
    Yes, following instructions from you and Miro, I checked the voltage to the orange relay. The "control signal" to the orange relay is the problem. It is being activated continuously after the car starts. The relay is doing as it should. Something upstream is the cause.
    Next steps are to investigate the test device module and to further investigate (and possibly remove) the added WR1 starter relay.
  5. seabass23
    seabass23 Karting
    Nov 6, 2016
    156
    St Albert, Alberta
    Matt
    #30 seabass23, Jun 9, 2023
    I unplugged the Test Device. With or without test device, there was a light glow at pin 86 of the orange relay with the key in accessory position. The test device is not the problem.
    Then, I removed the added WR1 starter relay and bench tested it (again). Without power - infinite resistance, with power - closed connection. It tests fine but regardless, I returned the ignition wire directly to the starter. This time, turned key on and NO more glow on the test light! Pump runs normally and remains active after starting. Test drove the car, made multiple hard stops with perfect braking and ABS working. We just SOLVED IT! Thank you guys so much!
    Now, somebody explain how the WR1 relay could cause this??? I had it installed under the air box, zip-tied to a cross-member just above the starter (as others have done per the DIY instructions on this site). Could a magnetic field from the proximity to the starter be the culprit?
    Qavion likes this.
  6. Qavion
    14,605
    Ian Riddell
    #31 Qavion, Jun 9, 2023
    I don't think the mystery has been solved just yet.
    There shouldn't be any current flowing through the starter when the car is running.... unless the start system is set up like the F355.
    @m.stojanovic Miro, doesn't the 348 have some kind of system to cut out heavy current devices like headlights and windscreen wipers during start? I can't find a relay for this in the wiring diagrams (at least not in the 2.5 diagrams). On the F355, there is a special relay that shuts down the heavy current devices during start. The relay is de-energised during start (by putting voltage on both sides of the coil). When the relay is energised, allowing power to the headlights and windscreen wipers, the start relay solenoid/coil becomes part of the earth circuit for this special relay. Because the current goes through two coils, it's not sufficient to energise the starter. I think you or some other electrical guru explained this to me previously.
    Well, that's the simplified explanation. On my F355, you can pull the lead off the starter and the special relay coil still manages to find an alternate path to earth. e.g. through the coil of the Brake Test Module.
  7. seabass23
    seabass23 Karting
    Nov 6, 2016
    156
    St Albert, Alberta
    Matt
    True enough. At least I have brakes that work properly!
    Qavion likes this.
  8. m.stojanovic
    m.stojanovic F1 Rookie
    3,314
    Serbia - Niš
    Miroljub Stojanovic
    The mystery is about what is keeping some "floating" voltage on the "START" line. Since it is not the Test Device, there must be some other device connected that needs the "START" signal. Anyhow, since everything works well (including the Test Device ?) with the Starter Relay removed, there is probably no need to investigate why there is that weak floating voltage on the line to the starter solenoid (possibly caused by a kind of relief relay that could be present on 348-s for some markets). The following drawing explains why the Orange Relay is held "on" after the key is released back from the START position.
    Left Drawing: When the Starter Relay is not present, the START current is applied to the starter solenoid and the Yellow Relay - both are switched "on". When the START current is switched off (the engine has been started), the starter solenoid coil, which has very low resistance, represents a grounding point to the "+" side of the Orange Relay and the relay is instantly switched "off". At the same time, any "floating" voltage/current on the START line is also grounded via the starter solenoid coil and will have no effect on the Orange Relay. So, in the factory setup, the START line is +12V with the key in START and it is ground when the key is released back to "RUN".
    Right Drawing: Wen the Starter Relay is installed (inserted), the grounding effect of the starter solenoid is removed and we have two relays connected to the START line which carries the mysterious floating voltage. This voltage/current is obviously not strong enough to switch "on" the two relays otherwise it would cause the starter motor to engage before the key is turned to the START position. What is happening is that, after the key is released back from START, the Starter Relay will go off (maybe with some delay) but the orange Relay will not. The reason for this is because the holding voltage of the Starter Relay happens to be higher so the weak floating voltage will not hold it but the Orange Relay is probably more sensitive (efficient) so the weak voltage will still be enough to hold the relay "on". The holding voltage of standard relays is usually some 5-7 volts.
    If you still want to have the benefit of the Starter Relay, do not use any of the standard car cube relays (~90 Ohm coil resistance) but a motorcycle starter relay (this is what I have on my 348). These relays are also quite compact but their coils have much lower resistance (some 5-10 Ohm) which will "eat" (channel to ground) the floating voltage almost as well as the starter solenoid coil. There are many types of motorcycle starter relays. You can go for a genuine (Honda, Kawaski etc.) or for an aftermarket one. Some examples:
  9. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,293
    CT
    John Kreskovsky
    Sounds possibly like a bad ground some where. You know, like when you have a bad ground on a tail light and the instrument lights glow lights because the voltage is back feeding trying to find a way to ground. (2002 Toyota pickup problem. :))
    Qavion likes this.
  10. seabass23
    seabass23 Karting
    Nov 6, 2016
    156
    St Albert, Alberta
    Matt
    Ah, excellent writeup, as usual!
    After @Qavion commented that it might not yet be totally solved, I did one more test last night. I was still wondering if there was still some further upstream issue (a source of the floating voltage, as you call it), such as the ignition switch. I pulled the ignition wire off of the starter and checked it with my test light, fully expecting to see some voltage with the key in the on position. With key on there was nothing, bright glow with key cranked, and back to nothing in the run position. The only time that the floating voltage is present is with the WR1 relay installed.
    Your suggestion of the motorcycle relay is duly noted but, just for fun, I may locate another cube solenoid and try it to satisfy my own curiosity.
    Qavion likes this.
  11. GTO Joe
    GTO Joe Formula 3
    1,002
    Charlotte, NC
    Joseph Troutwine
    Please let us know what you find out because there a number of us that have that starter switch installed. Glad you found what was causing the problem.
  12. Qavion
    14,605
    Ian Riddell
    For info, there are no diodes (in the brake light circuit) of the Euro version of the Test Module. I'll see if that's the same for the USA version when I get it.
    I didn't physically open the module to look for diodes. The module case looks hard and brittle, so I didn't want to risk opening it. I just did external resistance checks on the module pins. i.e. the coil is around 78 ohms.
  13. m.stojanovic
    3,314
    Serbia - Niš
    Miroljub Stojanovic
    #38 m.stojanovic, Jun 10, 2023
    As Matt informed, the "floating" voltage was still present on the Start line after unplugging the Test Device so it does not seem to be the cause of the issue with the Orange Relay (when using the Starter Relay).
    If it is not the Test Device, then there could be a so called Relief Relay connected the the Start line. These relays are usually connected between the "Ign 12V" and the Start line and their normally open (NO) contacts are used to switch certain things off while cranking the engine. This is usually the high consumers like heater blower, radiator fan(s) etc.
    Ignoring the Orange Relay for the moment:
    With the factory setup (left drawing), the Relief Relay gets +12V at ignition "on" (RUN) and has ground through the Starter Solenoid (which has just about 0.3-0.4 Ohm). So, at RUN key position, the Relief Relay is switched "on" providing power to the mentioned consumers. With the key in START position, the Start line gets +12V and the Relief Relay, having +12V on both sides of its coil, goes "off" cutting the power to the consumers. When the key is returned to RUN, the Relief Relay is switched back "on".
    With the Starter Relay installed (right drawing), its coil, having resistance of some 85 Ohms, does not provide good ground for the Relief Relay and this may cause, in some cases, the Relief Relay not to switch "on" at all. Furthermore, the current flow through the Relief Relay may cause the Starter Relay to stay "on" after the key has been released from the START position causing the engine to continue cranking until the ignition is completely switched "off". This is because the Relief Relay and the Starter Relay coils are connected in series between "Ign 12V" and ground which results in about 6 volts on the Start line (the relay coils act as a voltage divider, 2 x 85 Ohm).
    With the Orange Relay included in the "equation", we have 85 Ohm on one side of the Start line (the Relief Relay) and 42.5 Ohm on the other (2 x 85 Ohm in parallel of the Starter and Orange Relays). This voltage divider, having 85 and 42.5 ohms, will cause about 4 volts to be always present on the Start line (when the ignition is "on"). Even though quite low, the 4 volts seem to be enough to prevent the Orange Relay from switching "off" after it has been energised during cranking of the engine (just read that some standard car relays will not go off until the voltage on their coils is reduced to less than 2 volts). And the "divided" voltage can be higher if the Relief Relay happens to have somewhat lower coil resistance than the other two relays.
    I once had a problem on my BMW E30 when I installed a standard cube relay as the Starter Relay. The E30, as I discovered, has two Relief Relays (2 x 85 Ohm = 42.5 Ohm) connected to the Start line (resulting in 8 volts on the Start line from the "voltage divider") and they caused my Starter Relay to stay "on" (and continue cranking the engine) after I released the key from START. Installing a motorcycle starter relay solved the problem.
    seabass23 and Qavion like this.
  14. Qavion
    14,605
    Ian Riddell
    Yep... Just for info for future (different) problems.
    I was looking for these devices earlier. On the 355, 550, 360 etc... there is a specific relay, but I couldn't seem to find one in the relay list the 348 or in the diagrams.
  15. m.stojanovic
    3,314
    Serbia - Niš
    Miroljub Stojanovic
    Then Matt should reconfirm that, after unplugging the Test Device, the Orange Relay was still not switching "off" after cranking, i.e. that the ABS Pump was still not operating after the engine has been started.
    It is also possible that a Relief Relay (or a relay for some other function) was an additional installation on Matt's car by the PO or dealer.
    Matt, if you are going to experiment with other standard cube relays as the Starter Relay, be prepared for the possibility of having your engine still being cranked after you release the key from START. If this happens, just turn the ignition key to "off".
  16. seabass23
    seabass23 Karting
    Nov 6, 2016
    156
    St Albert, Alberta
    Matt
    Yes, I can confirm that, with the test device removed, I still had voltage at pin 86 of the orange relay after cranking.
    I have now tested another cube relay in the starter circuit. It's a brand new Bosch 0 332 019 155 with a diode across the coil. My previous cube relay was a generic relay with no diode (according to the diagram on the relay). The result was the same, voltage at pin 86 of the orange relay with the key on (but not cranking). There is approximately 3V present. So now we know that 3V is not enough to actuate the orange relay, but it IS enough to hold it after it has been actuated with 12V (and most seriously, impedes the operation of the hydraulic brake pump).
    If anyone with an added WR1 Starter Relay installed wants to do a test, it is relatively easy. I un-bolted the orange brake relay, flipped it upside down and took my voltage measurement on pin 86. Check voltage with key in all positions (on, cranking, run). You should ONLY see 12V present when cranking and 0V at all other times.
  17. Qavion
    14,605
    Ian Riddell
    Do you have an aftermarket alarm/immobiliser (or the remnants of one removed) somewhere in the start circuit?
  18. m.stojanovic
    3,314
    Serbia - Niš
    Miroljub Stojanovic
    The holding voltage (release voltage) of some 12V relays can be even lower than 3 volts. For example, Tyco V23234 Series car relays will release only when the voltage on their coils drops to 1.5 or 1 volt (depending on the version):
  19. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,553
    Jeff
    I'm running a WR-1 relay which I bought as a kit - the relay in that one is a Bosch 0 332 019 150
    I will say though that my ABS light is a bit temperamental but I suspect that's not to do with the relay though as it's slow to go out if I haven't used the car for a few days but does go out if I use it like a daily driver.
    I'm not sure how you do the test but if you post some clear instructions/pics up I don't mind trying it for you
    Qavion likes this.
  20. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Why use WR relay for hard start, why not solve the cause as opposed to mask it?
    Sent from my SM-G990U using FerrariChat.com mobile app
  21. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,553
    Jeff
    I think addresses an issue of poor design - similar to the "slow windows"
  22. Qavion
    14,605
    Ian Riddell
    Isn't the point of the relay to shift the heavy current devices from the cabin to the engine bay? i.e. no solenoid current going through the ignition lock contacts or relay panel.
  23. seabass23
    seabass23 Karting
    Nov 6, 2016
    156
    St Albert, Alberta
    Matt
    I do not believe so. The wiring seems "stock" with no obvious additions. No holes drilled in the dash/console for red blinking lights or anything light that. I will look again behind the dash and confirm.
    That was my primary motivation in installing the relay, a simple and inexpensive safeguard to extend the life of the costly ignition switch.
  24. m.stojanovic
    3,314
    Serbia - Niš
    Miroljub Stojanovic
    Perhaps you can do the following test: Disconnect the "Start" wire from the starter solenoid; connect a suitable extension wire to this wire, long enough so that you can bring it around and inside the car; unplug the orange relay; switch the ignition "on", keep on touching the ground with the extension wire and listen to any clicking.
  25. seabass23
    seabass23 Karting
    Nov 6, 2016
    156
    St Albert, Alberta
    Matt
    #50 seabass23, Jun 12, 2023
    I conducted your test. Shorting the "start" wire from the starter solenoid results in the clicking of this relay (with orange relay removed and with ignition on). You can see the empty location in the auxiliary holder that is attached to the main panel in the front trunk. It's not shown on the legend under the cover. It is the relay for the lights that turn on in the first position of the light stalk switch (trunk light, side marker lights, and orange lights in front bumper). When I short the wire, the lights turn on (without manipulating the light stalk) .
    Note that my car was made for the Canadian market if that makes a difference.
