Brake reservoir hose 125284 | FerrariChat
Discussion in 'Boxers/TR/M' started by jgmblair, Jul 19, 2023.
  1. jgmblair
    jgmblair Formula Junior
    813
    Winnipeg, MB Canada
    Jeff Blair
  2. Rifledriver
    37,096
    #2 Rifledriver, Jul 19, 2023
    The brown hose? Thats not a vacuum hoes, it supplies the clutch hydraulic system with fluid from the brake reservoir.
    Yes, its special hose.
    #119361 is indeed a vacuum hose but it is not in this picture.
    The brown hose is item 31 #125284 on table 29 of the 1990 TR parts book.
    I'd take it to someone to get it done.
  3. jgmblair
    813
    Winnipeg, MB Canada
    Jeff Blair
    Thanks Brian! I was in there doing Steve’s relay upgrade and inadvertently put my hand on the hose, the hose felt wet and left some residue on my hand.
  4. Steve Magnusson
    26,790
    It (the now-brownish hose in your photo exiting the side of the brake fluid reservoir) is a zero-pressure, zero-vacuum hose, as Brian indicated, but it (i.e., its inner liner layer) needs to be made of a material that is compatible with brake fluid (which is pretty nasty stuff).
    turbo-joe likes this.
  5. EDoug
    EDoug Formula Junior
    Apr 19, 2005
    266
    Southern Florida
    Jeff, the hose ID is 8mm to fit the plastic barbs. I had the same issue and used Cohline brake fluid capable hose. The core is polyamid hard plastic material with a rubber outer cover. Not a hard job BUT care is needed with the plastic barbs and this type of hose cannot be kinked. A hairdryer to soften the hose ends makes it a little easier to slide onto the barbs. Doug
    ago car nut likes this.
  6. jgmblair
    813
    Winnipeg, MB Canada
    Jeff Blair
    Thanks for the info! Will get it swapped out.
  7. ago car nut
    ago car nut F1 Veteran
    5,495
    Madison Ohio
    David A.
    The original hose looks typical of the type used on European cars, The cloth covering. I don't know if it all the same? Probably different specs for specific use.
  8. Motob
    Motob Formula 3
    Nov 11, 2003
    2,365
    Frederick, Maryland
    Brian Brown
    #8 Motob, Jul 23, 2023
    The original hose is made from EPDM rubber. That is what you should be looking for to replace it. Fuel/oil hoses are made from buna-n rubber, which is not compatible with brake fluid, and will swell and leak if used with brake fluid.
    There are many suppliers that carry the original cloth braided EPDM hose, 8mm is very hard to find. 7mm is easy to find and fits over the original fittings just fine.
    The original hose was dark grey/black in color, but turns tan/brown over time.
  9. Motob
    Motob Formula 3
    Nov 11, 2003
    2,365
    Frederick, Maryland
    Brian Brown
  10. jgmblair
    813
    Winnipeg, MB Canada
    Jeff Blair
    Thank you Brian! I see continental makes a black cloth braided 7mm ID hose for this application and it is readily available even up here in Canada ;)
    nathanmack28 likes this.
  11. Rifledriver
    37,096
    Thats a switch. The German government used to require low pressure brake fluid hose be blue as an identification method.
    Just be sure it is for brake fluid.
  12. EDoug
    Apr 19, 2005
    266
    Southern Florida
    The Belmetric site does have black 7mm cloth braided hose for brake fluid from Cohline. I did not want to risk the tight fit on the potentially brittle white plastic barb fitting. The original cloth braid hose that Ferrari chose for the Testarossa failed (felt wet and changed color) which I did not prefer to repeat. The Cohline M8x14 rubber covered polyamid hose seems more capable for preventing such seepage. The Belmetric spec sheet for same and it's use for brake fluid follows. EDoug
  13. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,526
    romano schwabel
    sorry brian: not right
  14. jgmblair
    813
    Winnipeg, MB Canada
    Jeff Blair
    Yes I did run across the blue hose on a few VW sites and now I understand why the hose was blue!
    I’ve just ordered a meter of this from a supplier up here.
    35006857512 Genuine BMW
    Audi, BMW, Mercedes, VW
  15. jgmblair
    813
    Winnipeg, MB Canada
    Jeff Blair
    How can I request to have the title of this thread changed to “Brake Reservoir hose 125284”
  16. jgmblair
    813
    Winnipeg, MB Canada
    Jeff Blair
  17. Rifledriver
    37,096
    Used to be the only choice available in fabric braided hose.
  18. Rifledriver
    37,096
    Its what the German suppliers all told us.
  19. Steve Magnusson
    26,790
    Just "report" your post #1 (on the left side at the bottom), and ask a Moderator to change the title to what you want.
  20. turbo-joe
    Apr 6, 2008
    9,526
    romano schwabel
    this would be totally new for me. I remember mercedes and BMW with yellow hoses. and in the written law I never read some about blue. so may be only the manufacturers made an agreement to produce those blue ones?
  21. Rifledriver
    37,096
    Its just what I had heard. For a long time it was all that was offered. American cars never used it so our sources used to all be European. Now with race cars and custom cars using it a lot is available from many sources.
  22. turbo-joe
    Apr 6, 2008
    9,526
    romano schwabel
    I asked today a friend of mine checking cars every 2 years for safety and he also not ever has known about this blue hoses. but he promised me to check and will let me know this or next week. I will write then again here, because I also like to know
  23. Basal Skull
    Basal Skull Formula Junior
    Oct 26, 2010
    427
    Vancouver BC
  24. jgmblair
    813
    Winnipeg, MB Canada
    Jeff Blair
    You should have sent me a text! The stuff I ordered is 1 metre, I would have just sent you a piece!
    Basal Skull likes this.
  25. daytonaman
    daytonaman Formula Junior
    May 1, 2007
    986
    Australia
    howard pigdon
