Brake reservoir tank 70000502 | FerrariChat
Discussion in 'Mondial' started by UsernameBob, Apr 26, 2025 at 4:54 PM.
  1. UsernameBob
    UsernameBob Rookie
    Jan 21, 2025
    17
    Rob Dyer
    Hi all,
    I was trying to replace the hose on my brake reservoir today and I heard a crack. Mine is pretty bad looking and had gone brittle. I believe it is the same as fitted to anti skid versions of the 208, 328, 348, 355. Would anyone know a place to get one? I am in the UK.
  2. 350HPMondial
    350HPMondial F1 Veteran
    5,288
    Edwardo
    The tank, ,,? same as the Alfa Romeo.
    CenterLine ,, I believe, is the distributor name.
    ,, used to be International Auto Parts.
    get the two bottom grommets,, ( seals ) ,, that hold the tank on to the master cylinder
  3. UsernameBob
    UsernameBob Rookie
    Jan 21, 2025
    17
    Rob Dyer
    Hi, thanks for the answer. I just had a look through their whole site and I could not see the right tank. Would you know the model of Alfa Romeo?
  4. 350HPMondial
    5,288
    Edwardo
    I’m guessing a 1983 Gtv6..
    I did one for a friend.
    I had to call them for the clutch master reservoir.
    They are quite helpful.
    good luck,
