Brake Squeal on 575M Fiorano Handling Pkg. | FerrariChat
Discussion in '456/550/575' started by VicG, May 26, 2005.
  1. VicG
    VicG Karting
    Feb 5, 2005
    115
    Fairfax County, VA
    Vic
    A dealer has told me that the brakes that were included as part of the Fiorano Handling Package on the 575M squeal like a banshee. Based on what I have heard from others, I have gathered that it is a known issue and not an isolated/occasional thing.
    Can anyone tell me how they have managed to deal with the issue? Did you change pads, or is the squealing not as bad as some would suggest? If you changed pads, how much did it cost, parts and labor?
    Thanks-
    Vic
  2. Carnut
    Carnut F1 Rookie
    Nov 3, 2003
    3,797
    Gladwyne PA
    Morrie
    My car has the package and I was unaware that the brakes were even part of the package. Both my 360's squealed at time, a heavy foot on the brake would usually get rid of it. My 575 is not as bad, not sure why a dealer would say that.
  3. WCH
    WCH F1 Veteran
    5,186
    My '03 575 w/Fiorano squealed at almost every brake application. A change of pads cleared up the problem.
  4. stephens
    stephens F1 Rookie
    Feb 13, 2004
    4,647
    Australia
    Stephen S
    The pads in the FHP are Pagid's. The service bulletin describing the kit clearly states this as a known problem, with no known rectification apart from replacement, although I have seen from past searches on the board here, that bevelling the edges of the pads seems to help.
  5. India Whiskey Charlie
    India Whiskey Charlie Formula Junior
    May 24, 2001
    554
    Way Out West
    #5 India Whiskey Charlie, May 26, 2005
    It is not a problem. All higher performance pads squeal. Ferrari provided an alternative for those who would rather have quieter pads.
  6. BWS550
    BWS550 Wants to be a mod
    Apr 1, 2002
    8,933
    NEW JERSEY
    BRUCE WELLINGTON
    LIKE EVERYONE SAYS
    I HAVE THE F PACKAGE ON MY 550
    THEY DO SQUEEL, IF IT BOTHERS YOU, CHANGE THE PADS, EASY FIX..
  7. WCH
    WCH F1 Veteran
    5,186
    "It is not a problem. All higher performance pads squeal."
    That's actually a very good point, we can't fairly call it a problem. I went to the softer compound pad on my 575 and of course noticed no performance difference at all in braking in street use (I never tracked the car).
    I once greatly annoyed my wife by putting Pagids on her 911 when it needed new pads. Not amused, she was.
  8. Martin Meade
    Martin Meade Karting
    229
    B'ham, WA
    Martin Meade
    Porterfield R4-S pads are what you want for low dust, no squeal, "spirited" street driving. We stock them as do others. We've sold them to a number of Ferrarichatters and all have been pleased.
    Martin
