Brake system layout for 308 qv | FerrariChat
Discussion in '308/328' started by MrSweden, Oct 8, 2010.
  1. MrSweden
    MrSweden Karting
    Sep 30, 2008
    184
    Hasslö, Sweden
    Max
    Hi.
    I have a brake problem, the car drifts to the right during hard breaking. The mechanics tell me there is some kind of distribution or slave cylinder to the front brakes. I wonder if there is anyone who has a Brake system layout for the 308 qv. The one I have is from 1978 and there the front brakes are connected too the master Cylinder and no slave or distribution cylinder are shown.
    MrSweden
  2. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,324
    Are you certain you havn't just got a sticking caliper?
  3. MrSweden
    MrSweden Karting
    Sep 30, 2008
    184
    Hasslö, Sweden
    Max
    Yes, we have done all we can with the calipers. And they är fine.
  4. chrismorse
    chrismorse Formula 3
    Feb 16, 2004
    2,150
    way north california
    chris morse
    #5 chrismorse, Oct 8, 2010
    Take a good close look at the front lower a arm mountng bolts. If the right rear has loosened and dropped a shim, the a arm will be pushed back under braking, causing toe out and reducing the camber a bit, all of which could cause a pull to the right.
    I do not believe that there is anything other than a master cylinder and proportioning valve in the hydraulic system, Neither of which would cause a pull - check the suspension, both sides, front and back.
    hth,
    chris
  5. viper_driver
    viper_driver Formula Junior
    Jan 1, 2009
    978
    Vegas
    Jason
    My car did the same. 4 wheel caliper rebuild and now they're perfect. If your brakes haven't been rebuilt, it's time.
  6. Paul308GTSi
    Paul308GTSi Formula 3
    Oct 26, 2008
    1,003
    Queensland Australia
    Paul D
    Get a totally different mechanic to do the right front caliper ....
    and if it comes good then it was not fixed properly by the first guy who said it has all been done.
    ........... then fix the other 3 because they are all about to go the same way.
