Brake Vacuum non-return valve | FerrariChat
Discussion in 'Technical Q&A' started by jselevan, Nov 24, 2005.
  1. jselevan
    jselevan Formula 3
    Nov 2, 2003
    1,879
    Does anyone know where I can get one for a 246 GT Dino? It appears to be the same for early 208 and 308 vehicles as well. This is the one-way check valve between the intake manifold and the vacuum assist unit at the master cylinder.
    UK does not have, nor does GT car parts. Is there a similar unit for another car?
    Thanks.
    Jim S.
  2. chrismorse
    chrismorse Formula 3
    Feb 16, 2004
    2,150
    way north california
    chris morse
    Try a search for the above mentioned part or Durable-1. There have been a fair number of posts regarding the effectiveness of the valve.
    Basically, the valve opening threshold is less than the stock valve, so it admits a greater amount of vacuum to the booster to help you push down the pedal.
    It is not a huge improvement but it is worthwhile.
    hth,
    chris
  3. jselevan
    jselevan Formula 3
    Nov 2, 2003
    1,879
    Chris - thanks for the response. My issue is not that it was not functioning correctly, as far as I could tell, but now that I have it out (during a complete restoration), I wish to replace it. When I blow through each end, it does not seem to have proper action (sealing or free-flow).
    Do I read your post correctly that I should search on Durable-1 for the non-return valve? Is Durable-1 a web site, or a text string in a post on F-chat?
    Thanks.
    Jim S.
  4. chrismorse
    Feb 16, 2004
    2,150
    chris morse
  5. jselevan
    jselevan Formula 3
    Nov 2, 2003
    1,879
    Chris - thanks - exactly what I needed to read.
    Jim S.
