Brakes 400I | FerrariChat
Brakes 400I
Discussion in '365 GT4 2+2/400/412' started by CARUSO, Feb 12, 2018.
  1. CARUSO
    CARUSO Rookie
    Feb 2, 2018
    25
    For 400I Auto year 1984 DOT3 or DOT4 ?
  2. Ferraridoc
    Ferraridoc F1 World Champ
    Jun 20, 2012
    17,218
    Gold Coast, Aust.
    Patrick
    IDK, but it'll be in the manual
  3. Part Time
    Part Time Formula Junior
    500
    Port St. Lucie, Fl
    Gary Shore
    DOT 3 is original fluid, don't mix brake fluids, you could use DOT 4 if you are completely cleaning/flushing the entire brake system, 4 has a higher boiling point.
    Gary
    PS: Use the "search" function on top of page, click "more" to enter key words & search only this forum. Lots of good info here.
  4. It's Ross
    It's Ross Formula 3
    Jul 30, 2007
    2,028
    Barrington, Ill. USA
    Ross
    #4 It's Ross, Feb 13, 2018
    No problem mixing DOT 3 & 4 as they are both glycol based. Boiling point of a mixture would be tough to calculate but would ostensibly be an improvement over 100% DOT3.
    It's DOT 5 silicone fluid that shouldn't be mixed with others. If going to DOT 5 which is not hygroscopic thoroughly flush all the old fluids first. Dot 5 should only go into a dry system which is going to require some dismantling.
  5. Nobbi
    Nobbi Rookie
    Apr 26, 2005
    9
    Center of Germany
    You can use DOT5.1 which is also a glycol based fluid with higher boiling point than DOT3 and DOT4.
    I would never use DOT 5 in a glycol fluid based brake system because there i s danger of destroying the rubber parts. Results are clear if this happens.
