355 - Brakes ineffective after driving spiritedly | FerrariChat
355 Brakes ineffective after driving spiritedly
Discussion in '348/355' started by Johnnieblack115, Apr 29, 2023.
  1. Johnnieblack115
    Johnnieblack115 Karting
    Nov 18, 2022
    220
    Massachusetts
    Jonathan Walker
    Took my car out on some back roads this morning and after getting it up to temp I started driving it between 5/10ths and 7/10ths.
    After turning around to make my return I was startled to find no matter how much pedal pressure I applied my brakes weren’t responding. My pedal is typically stiff but it felt like I was pressing on a brick and my pads were made out of glass.
    Puzzlingly, after pulling off in a parking lot and shutting the car down I couldn’t find any obvious problems. When I turned the car back on, the brakes worked normally again until I got to the foot of my driveway and then very similar symptoms again.
    Is this a fluid loss issue or would the root cause be vacuum related?
  2. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,724
    If the pedal is stiff but you are not getting retardation, the pads are the likely culprit.
    {I had such an event on the race tracks and had to "leave the paved surface" even with fresh (3-day old) brake fluid.}
    In my case, the <front> pads taken out of the calipers looks like wood that had been eaten by termites.
    Higher temperature pads (Ferrodo DS2500) solved the track temperature problem.
    A fluid loss (or boiled fluid) would not result in the brakes "coming back" after a bit of cooling.
    A failure of the vacuum pump would not result in a stiff feeling pedal.
  3. Johnnieblack115
    Nov 18, 2022
    220
    Massachusetts
    Jonathan Walker
    This is exactly the rational breakdown I needed. The crazy thing is that I wasn’t even pushing the brakes. Some heel-toeing on a few corners. That being said I’m suspicious that the pads are exerting too much on the rotor at all times. The pads themselves look to have plenty of life in them though
  4. fboutlaw
    fboutlaw Formula Junior
    Dec 3, 2014
    260
    Woodside, CA
    I would try to get your car into a shop. To me, that sounds like a clog if the pedal was very hard and you weren't getting braking. If the pedal was working normally, I'd suspect that your brakes were glazed over or not bedded properly... or that you chewed through the pads, but you ruled both these out in your description.
    Good luck, this one seems a bit dangerous.
  5. Zamboniman308
    Zamboniman308 Formula Junior
    Feb 2, 2020
    504
    Chicago IL
    Gelled clogged fluid?
  6. fatbillybob
    Aug 10, 2002
    28,989
    socal
    brake booster circuit
  7. PAUL500
    PAUL500 F1 Rookie
    Jun 23, 2013
    3,136
    Fail safe on the ATE Teves anti lock system is to revert to normal passive braking, which could explain the difference in pedal feel, until it kicks back in.
    Not sure about the Bosch version but imagine it is the same.
    Sounds like glazed pads though, that is the easiest first course of action to resolve initially.
    Fluid loss/airlocks would result in a spongy pedal and the abs pump kicking in constantly.
  8. Johnnieblack115
    Nov 18, 2022
    220
    Massachusetts
    Jonathan Walker
    I’ll take the pads out today to check. Would cool glazed pads still have some bite that disappears as they warm up?
  9. fatbillybob
    Aug 10, 2002
    28,989
    socal
    That's why I said booster circuit. If your post is accurate that's not glazing because glazing does not come back. Once glazed pads are done.
  10. PAUL500
    PAUL500 F1 Rookie
    Jun 23, 2013
    3,136
    Do you hear the abs prime on start up? and the pedal having a pulsing feel? system failure is usually a seized pump or a faulty sensor, usually attributed to a nick in the loom somewhere or water getting into the joint where the sensor attaches to the loom.
    You can attempt to get the glaze off the pads with a palm sander and a low grit pad, but given it is a cheap option then replacement is best, win win really as even if this turns out not to be the cause you have fresh pads and one less item on the list of possible causes.
  11. Johnnieblack115
    Nov 18, 2022
    220
    Massachusetts
    Jonathan Walker
    Yeah this seems like the lowest hanging fruit in terms of troubleshooting. Is there a general consensus on a preferred street pad setup? EBC yellow?
    In terms of the abs priming, I’m not sure what nose to listen for. I’ll check out YouTube. In case you couldn’t tell, this is my first time addressing a brake issue outside of pads and rotors
  12. Johnnieblack115
    Nov 18, 2022
    220
    Massachusetts
    Jonathan Walker
    Also no pulsating pedal on startup but possibly some while driving. I’ve also heard a sort of “squelch” sound braking once before
  13. PAUL500
    PAUL500 F1 Rookie
    Jun 23, 2013
    3,136
    The pump should sound like a servo motor at start up until the system is pressurised then switch off. I am going off another car equipped with the same system so have to assume the 355 operates the same way, hopefully a current owner can confirm for you.
    Is yours a ATE Teves or a later Bosch car?
  14. squid
    squid Karting
    Oct 5, 2006
    153
    If your calipers are sticking it can cause the pads to overheat even without hard braking.
  15. Johnnieblack115
    Nov 18, 2022
    220
    Massachusetts
    Jonathan Walker
    So I just went to check on the ABS module and in doing so I noticed the reservoir is completely empty from what I can see. The weird thing is that my clutch still works and my brake pedal has kept pressure (I.e. the pedal never dropped to the floor). If I lost all fluid I would assume the clutch wouldn’t be functional and the brake pedal shouldn’t have any resistance to being being depressed correct?
  16. Johnnieblack115
    Nov 18, 2022
    220
    Massachusetts
    Jonathan Walker
    This was my first thought but my abs light is on as well.
    Also I can hear the pump prime when the ignition is on but the engine isn’t running. It seems to just be continuously on as I left it in that configuration for about a minute and it just kept going before turning it off. With the engine running it’s too loud to tell if the pump is on or not. I’m guessing there’s a leak and the pump is never getting adequate pressure. It’s just odd that with the reservoir just about empty that the brake pedal and clutch are still functioning. The brake pedal gives substantial resistance to being depressed and the clutch operates no differently than any other car I’ve driven
  17. PAUL500
    PAUL500 F1 Rookie
    Jun 23, 2013
    3,136
    The clutch is on a separate circuit, it does not share fluid with the brakes.
    There is probably enough fluid in the braking circuit to allow the pump to keep sufficient pressure to provide a solid pedal, but that pump is working overtime in order to do so, and will burn out as a result, time to top it up and that will allow the pump to prime and then switch off, if it then loses fluid again, then yes you have a leak/s
    squid likes this.
  18. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,892
    Richmond
    Pete
    When was the last time the brakes were bled? I would start by thoroughly bleeding the system with fresh fluid and checking for leaks - the reservoir being low and pump running extra are major red flags that you have a fluid leak somewhere - unless it's been a really long time since the system was bled.
    I've overheated the pads before on track but it took threshold braking from very high speed (140+mph), and street driving should not stress the brakes much unless you're driving like a total lunatic. I moved to Hawk black pads - they generate a lot of dust but are easy on the rotors as those are a lot more expensive to replace than the pads.
  19. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,219
    CT
    John Kreskovsky
    No brake warning light?
  20. Johnnieblack115
    Nov 18, 2022
    220
    Massachusetts
    Jonathan Walker
    This car is a Christmas tree lol it’s got every warning light
  21. Johnnieblack115
    Nov 18, 2022
    220
    Massachusetts
    Jonathan Walker
    Well I put two bottles of DOT5.1 liquimoly and the pump now turns on only briefly so the continuous running was definitely from that.
    I’ve had what I believe I now misdiagnosed as an oil leak but it could be a leak in the line going to the right rear tire. The fluid looked like oil and was slick to touch but only produced puddles after driving. That coupled with the brake outage leads me to believe this was from the brakes rather than oil
  22. Johnnieblack115
    Nov 18, 2022
    220
    Massachusetts
    Jonathan Walker
  23. Targatime
    Targatime Formula 3
    Feb 22, 2014
    1,449
    Los Angeles
    Yeah, why take a closer look at puddles of fluid under your car, just drive and enjoy, probably nothing
  24. Johnnieblack115
    Nov 18, 2022
    220
    Massachusetts
    Jonathan Walker
    I’ll add that the puddle pictured above accumulated over the course of a couple days post-drive
  25. Zamboniman308
    Feb 2, 2020
    504
    Chicago IL
    There is a brake line coupler in that area that is disconnected when removing the engine cradle. May be leaking there. However your other thread referenced leakage above that area. Perhaps there are multiple leaks.
