Brakes squeal | FerrariChat
Brakes squeal
Discussion in '360/430' started by PrestonP, Sep 28, 2012.
  1. PrestonP
    PrestonP Rookie
    Aug 29, 2012
    48
    SE Michigan
    Just purchased a 2003 spider with 13.7k miles. The dealership indicated the brakes were replaced late last year and are practically new. However, they squeal when light pressure is used when braking. This is very annoying and as you know embarrassing. The dealer said apply heavy pressure and after awhile, it would go away. Yes, heavy pressure does work, but who wants to always apply heavy pressure
    400 miles later they still squeal. Any suggestions on the easiest way to solve this issue?
  2. djastral69
    djastral69 Formula 3
    1,896
    Fl
    David
    You will likely have to 'Bed' them in, do a search and follow the procedure and that should take care of your brake squeal woes :)
  3. Ingenere
    Ingenere F1 Veteran
    Dec 11, 2001
    6,451
    On the Limit
    Dino
    The brakes need to be 'APPLIED'. Your light technique is just glazing the rotors.
    A couple of track days will get rid of the sound, until you glaze them again.
  4. ttdang123
    ttdang123 Formula Junior
    Nov 28, 2009
    706
    North San Diego CA
    Tung
  5. agup48
    Apr 15, 2006
    28,633
    Phoenix
    AG
    PS. You brakes were squealing last Cars and Coffee. I think another track day is in order! :p
  6. DrDoug
    DrDoug Formula Junior
    Dec 4, 2009
    384
    San Jose, CA
    Doug T
    When I got my 360 the brakes squealed really loud. I tried all of the bedding-in procedures described in previous posts and while it helped a bit, the squealing never went away. My mechanic said that the pads that were previously installed were causing the problem. He switched the brake pads back to OEM pads and the problem went away.
  7. ferrari355gtb
    ferrari355gtb Formula 3
    Nov 3, 2003
    1,600
    R
    Did you question why the brakes needed replacing after 13k miles - something doesn't add up, either the mileage (???) or excessive wear (track) ?
  8. Nathan360
    Nathan360 Karting
    Apr 17, 2010
    154
    Manchester / England
    Nathan
    mine squeal more when I use alloy wheel cleaner.
    Track day where I boiled brake fluid and turned rotors different colour stopped the noise till I washed the wheels again
    Hi Mr B
  9. smin9870
    smin9870 Karting
    Mar 6, 2011
    78
    CT
    Steve
    Any time I've used alloy wheel cleaner on any car (porsche, volvo, bmw) it causes the brakes to squeal for a while. I think whatever chemical it is that removes the brake dust on the rim also eats away the "bedded"pad residue on the rotor as well and causes squeeling until the brakes are bedded again. Totally stopped using the crap.
