Brakes | FerrariChat
Brakes
Discussion in '308/328' started by cessna, May 28, 2010.
  1. cessna
    cessna Karting
    Dec 4, 2008
    226
    Malta
    Stephen Grech
    Hi, having three cars (VW Golf and Citroen Picasso) besides my baby 328, I rate the brake performane of my 328 the worse of the lot.
    The deceleration rate is far less then the other cars. Any feedback re your 328 braking performance.?
    Cheers
    Stephen
  2. st@ven
    st@ven F1 Rookie
    Aug 4, 2008
    3,315
    Germany
    Steven
    #2 st@ven, May 28, 2010
    i would agree. When i first drove my 328 after purchase the brakes were actually disapointingly bad.
    After some investigatings I upgrades the pads to EBS yellowstuff and by doing that (and only that) I complete transformed the performance. Now i would rate them as far beyond avarage. (and better than my Audi a6 quattro)
    Obviously there more good pads, but bottum line is that by changing to the right modern pads you can increase performace considderable.
  3. cessna
    cessna Karting
    Dec 4, 2008
    226
    Malta
    Stephen Grech
    I use the original Ferodo brake discs.
    What brand are these yellow discs?
    Thanks.
  4. MondialNeil
    MondialNeil Formula Junior
    Apr 2, 2007
    427
    Bucks,UK
    Neil S Perry
    YellowStuff are brake pads, that is what he is saying to change, they are made by EBC.
  5. mikael82
    mikael82 Formula Junior
    Nov 18, 2007
    869
    Finland
    Mikael
    #5 mikael82, May 28, 2010
    Both 308's and one Mondial QV cabrio I got, are all with original "bad" braking power, but there are HUGE difference to Monndial 3.2 cabrio I got. That car has original factory brakes and as instant you touch pedal you brake necks of all pasangers. If I remember right normal 308/328 serrie cars have 23mm mastercylinder. Mondial 3.2 got 25mm mastercylinder from factory and that makes those brakes like "from different planet".
  6. BillyD
    BillyD Formula 3
    1,829
    Pacific Northwest
    Bill
    I agree with replies above, change the pads & bleed the brakes. I changed my pads to EBC reds & WOW! what a differenence over the old ATS original.
  7. TheMac
    TheMac Formula Junior
    Sep 5, 2009
    452
    Alberta
    Jon Mac
    Haven't driven a 328 to compare, but... I agree with the statement about the 3.2 Mondial's brakes. The thing just stops. I am intrigued; is the master cylinder the only difference between the 3.2 Mondial and the 328? After all, the Mondial is considerably heavier than the 328. Mine is an ABS car, not that the ABS activates much (only twice in one year now). Did the later 328s have better brakes?
  8. mikael82
    Nov 18, 2007
    869
    Finland
    Mikael
    I got one without ABS
  9. cessna
    cessna Karting
    Dec 4, 2008
    226
    Malta
    Stephen Grech
    Ok. So I will order the yellow brakes.
    To be frank with all of you guys, today is one of those days which I don't feel like reading catalogues. What is the difference between Yellow, Green and Red discs.?
    Lazy Stephen :)
  10. Perfusion
    Perfusion F1 Rookie
    Oct 16, 2004
    4,151
    Marietta, GA
    Aaron
    Just to reiterate, EBC is the manufacturer, and Yellow, Green, and Red are different PADS that they offer.
  11. Mfoncerrada
    Mfoncerrada Formula Junior
    Dec 20, 2009
    419
    Monterey, CA
    Miguel Foncerrada
    Hey Lazy,
    Here is a good link that summarizes the uses of the different color pads.
    http://www.perfectbrakes.com/products.asp?cat=2637
    or search through the manufacturer's descriptions here
    http://www.ebcbrakes.com/selector.shtml
  12. CliffBeer
    CliffBeer Formula 3
    Apr 3, 2005
    2,198
    Seattle, Washington
    Cliff
    The brakes on my 3.2 mondial feel significantly more "boosted" than on my 308. However, I would rate the 308 brake calipers as better brakes from an engineering standpoint. The 3.2 has single piston floating calipers on the front that I believe are the same as a Toyota Corolla of equivalent vintage. The 308 has twin piston front calipers that are the same as a 911 of the same vintage (porsche is renowned for good brakes).
    It may not be just a matter of different booster levels. The 308 has the lateral placement of the MC with a mechanical mechanism in between to link it to the pedal - this is much less direct than the 3.2 which has a longitudinally place MC with direct link to the pedal.
    I've driven 328s that have a more "boosted" feel to the pedal than the 308. It would be interesting to see if anyone knows if the booster is the same between a (non-ABS) 328 and a 308....
  13. cessna
    cessna Karting
    Dec 4, 2008
    226
    Malta
    Stephen Grech
    I should have bought online the Yellow Stuff brake pads. When installed do they show.?
    Any pics please.?
  14. gigaleff
    gigaleff Rookie
    Feb 27, 2008
    47
    Switzerland
    I had my booster replaced last winter (328 non-ABS) and it seems that the boosters are all the same for Fiat Dino, 308/328 and Mondial.
  15. DGS
    DGS Seven Time F1 World Champ
    72,168
    MidTN
    DGS
    #15 DGS, May 30, 2010
    When you rate brake "performance", are you looking at stopping distance at maximum braking (just at the edge of sliding), or are you looking at pedal force required to break the tires loose (or trip the ABS)?
    I recently replaced the OEM pads on the EVO with R4-S pads. *
    (I probably should have scrubbed down the rotors to remove any residual material deposited by the old brake compound, but I had enough trouble just cleaning the accumulated crud off the backing plates.)
    With the old pads, very little brake pressure would cause everything in the car to wind up in the firewall.
    With the new pads, heavy braking will still trip the ABS, but it takes a lot more pedal pressure to get there.
    But the results are more controllable brakes.
    (And less squeaking from cold brakes in the city.)
    (And, hopefully, less dust. With the OEM pads, the rims would be black with brake dust after only a couple of months.)
    My (non-ABS) 328 has enough brake grip to cause the tires to come unstuck. Without fatter tires, "better" brakes aren't going to do much except make them more of a hair trigger, and make modulating the brakes harder.
    I've been considering putting R4-S pads on the 328, too (despite losing the sensor contact), because the ATEs blow out a bit of dust too, although they don't squeak quite as badly when cold as the EVO's brakes did.
    (I suspect that just cleaning the backing plates would reduce the squeaking.)
    * Ever see those old movies where they'd push in one drawer only to have two others pop out?
    That's what it's like, changing pads on a four pot caliper. ;)
