Brands of gas: which to use, which to avoid: | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by Gatorrari, Jul 10, 2004.
  1. solly
    solly Formula 3
    Jun 2, 2001
    1,148
    Westchester NY
    Dr. Steven S.
    Sunoco 100 is designed for cars, and is unleaded. Airplanes using 100 octane gas use LL as described below since their engines are designed for low lead gas. Do not put 100LL into your car!!. Will screw up the cats eventually, and if you have a late model (355, 360), will cause the engine malfunction light to come on as the sensors get screwed up.
    For those geniuses I recently met who were going to the airport to get some "jet fuel" I tried to explain that it is basically kerosene but they were determined to give it a shot. The gene pool has no lifeguards.
    In answer to 911's question- I need 100 octane to run a 360CH car. If I start out at 94 I will have a shorter way to go using octane booster to get to approx. 100. It will run on 97-98 (even 93 in a pinch), but it doesn't like it.
  2. DGS
    DGS Seven Time F1 World Champ
    73,878
    MidTN
    DGS
    100LL avgas is only "low lead" compared to older avgas. 100LL has more lead than regular leaded auto gas.
  3. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    One must be quite cautious with additives. The lead boosters had us doing valve jobs on an untold number of Jag 12 cylinder cars when it would send a glob through and stick a valve open. Until I track down what the cause of this little problem was (http://ferrarichat.com/forum/showthread.php?t=23286) I am having my customers stop using all octane boosters and fuel additives.
    Dave
  4. solly
    solly Formula 3
    Jun 2, 2001
    1,148
    Westchester NY
    Dr. Steven S.
    Dave- I thought octane boosters had no lead, but used toluene (as stated below, and as I remember so well from organic chemistry) to boost octane. Wouldn't lead in an additive ruin the catalytic converters, to say nothing of the problems you mentioned?
  5. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    True to all. I was making a point in general with a few additives we have seen used. Tolulene is some nasty stuff! Used to run it in high concentrations in the race cars. One could always tell who followed who. The tailing driver always looked like his eyes were bleeding.
    I still do not know what melted all of the rubber in the fuel pumps, but will find out in short order. I have the remainder of the rubber out being tested.
    Dave
  6. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,677
    Toronto / SoCal
    Rob C.
    I only use Shell for no reason other than they sponsor the F1 team. I am such a sheep.
  7. Darolls
    Darolls F1 Veteran
    7,782
    Sparky
    As long as it's not Trinitrotoluene! :)
  8. judge4re
    judge4re F1 World Champ
    Apr 26, 2003
    13,477
    Never home
    Dr. Dumb Ass
    Just takes nitric acid and ~140 C to make it. Not a recommended back yard project.
    Ah, the stuff you learn in organic chemistry.
  9. Jet-X
    Jet-X F1 Veteran
    Nov 2, 2003
    5,694
    Washington State
    Brian
    California varies, from 91 octane to 92 octane pending area and gas station. I've run it all (Chevron, Mobil, Shell, Union 76) and even Unocal 100 octane (noticed NO difference in performance, gas mileage, etc.)
    However, I did get a bad tank of gas from a Shell station. Put premium in, and the minute I left, pinging like crazy. I didn't know anything about pinging at the time (no, no damage done) until later that night. Needless to say, I will a) never fill from Shell again, and b) never from that particular station.
    I remember the next day I was visiting Mr. Leno (yeah, that one), and I mentioned I got a bad tank of gas of which my wife rolled her eyes. He said there is no such thing as a bad tank of gas. He thought I let the gas too low, and introduced air bubbles in my fuel system. When I explained everything, he said "you got a bad tank of gas" and proceeded with some jokes. At least it shut my wife up about bad gas.
  10. Fiat Dino 206
    Fiat Dino 206 Karting
    Apr 19, 2004
    144
    Mississippi
    David
    I have a question for the crew ...
    would not a modern car with all the computers, solenoids and analyzers and such read the combustion gasses along with a few thousand other things and then adjust the running of the vehicle to try to mimic the prefered characteristics of design regardless of octane, as long as the octane is above the minimum recommended?
    Modern computerized cars:
    I have always been told that if a car maker recommends 87 octane unleaded that there would be no difference in the performance of the vehicle if one fills the tank with 93 octane. The reasons given by the mechanic is that the vehicle will change the timing or whatever to adjust the performance and emissions to closely approximate the same numbers as it would have made with 87 octane?
    In other words, if someone put 100 octane in a 360 would the performance of the vehicle be better? More power, faster acceleration etc.?
    Your thoughts?
    Best wishes
  11. Slim
    Slim Formula 3
    Oct 11, 2001
    1,735
    Pacifica, CA, USA
    richard
    In general, the modern systems will retard timing (etc.) to deal with lower octane gas, thus robbing performance. There was an article in road and track where they tried to make the cars work the other way around: they wanted to know if they put in higher octane than spec called for, would the car perform better. They found some cars ran the same, but a few performed better. I seem to recall they were turbos.
  12. solly
    solly Formula 3
    Jun 2, 2001
    1,148
    Westchester NY
    Dr. Steven S.
    The 360 Challenge car has a motor identical to the 360 modena/spider. Yet the specification is 100 octane for the Challenge, and 93 for the road cars.
    This leads me to believe that the software for the Challenge car is different, and allows it to take advantage of the higher octane. I do know that the SD-2 unit has different programming for the street and Challenge cars, so the ECUs and their performance are different.
    I'm not sure that the stock ECU on any car would take advantage of higher octane gas without some reprogramming.
  13. smsmd
    smsmd Karting
    Nov 12, 2003
    150
    San Jose, California
    Steven Scates MD
    I have a friend who owns a Calif Exxon distributorship. He says the gas in his trucks is coming from a common tank, to which the additive is then placed. Multiple brands are filling from the same gas source, then adding their own additives.
    No doubt some bias here, but he feels the additives and turnover at stations does matter.
    steve
  14. ghost
    ghost F1 World Champ
    Dec 10, 2003
    10,046
    Singapore
  15. Paul Vincent
    Paul Vincent Formula Junior
    Apr 3, 2004
    478
    Back in February of '74 I got a tank of bad fuel that nearly had us break down on a frozen winter's night on I-74 (when our son was six or so weeks old). I almost destroyed my engine/drivetrain as I drove on til we reached a closed gas station. As the town was small, the first person we met knew the owner and got him to come help us. If you've never had bad fuel, count your blessings. Needless to say, never bought fuel at that station again.
