Break Help (308) | FerrariChat
Break Help (308)
Discussion in '308/328' started by sapple89, Mar 23, 2008.
  1. sapple89
    sapple89 Karting
    Oct 21, 2006
    101
    L.A.
    sapple
    1982 308 gtsi
    The breaks work but are EXTREAMLY hard to press and bring it to a complete stop. Is there some kind of pump/vac that may have gone bad? How hard is it to replace?
  2. mksu19
    mksu19 Formula 3
    Jan 4, 2008
    1,864
    LAX / YVR / MNL
    Capt. K. Banzon
    Oh you mean the BRAKES! Sounds like a master cylinder problem. I'd use the search function or maybe even browse in the Tech Section to get some answers. But Im sure someone here would chime in soon. Good luck man!
  3. moretti
    moretti Five Time F1 World Champ Lifetime Rossa Owner
    Nov 1, 2003
    59,757
    Australia
    probably got a split in the vac hose .... I replace all my hoses every 5 years, it stops a lot of these issues
  4. miked
    miked Formula Junior
    Feb 7, 2001
    897
    Cincinnati, Ohio
    Classic symptoms of no vacuum to the brake booster. A sticking check valve in the vacuum line would be the first thing to look for. Clean the valve with some carb cleaner. It should rattle when you shake it similar to what the typical PVC valve sounds like. If it sticks open the vacuum doesn't stay trapped in the booster.
    Lots of threads on the subject.
