Breif Milky Brake Fluid at reservoir only | FerrariChat
Discussion in 'Technical Q&A' started by nautigirl, Aug 8, 2014.
  1. nautigirl
    nautigirl Karting
    Feb 26, 2007
    109
    Hermosa Beach
    crash
    Hi all,
    I recently put replaced my brake lines with stainless. I had 1 defective line. I had to put the original back, car back on dirt and it ran fine.
    Yesterday I replaced the one line, bleed the line. I pumped the brakes while it's still up in the rack and noticed when
    I checked the reservoir a milky layer moving across the top of the fluid. Waited about a long minute and the fluid returned to normal? Is this normal?
    Should I bleed again? Thanks for the advice.
    cheers,
    crash
  2. nautigirl
    nautigirl Karting
    Feb 26, 2007
    109
    Hermosa Beach
    crash
    Spell check mate, make that "brief" milky brake fluid,
  3. nautigirl
    nautigirl Karting
    Feb 26, 2007
    109
    Hermosa Beach
    crash
    #3 nautigirl, Aug 8, 2014
  4. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,732
    Complete flush is in order.
  5. 360Tom
    360Tom Formula 3
    May 9, 2013
    1,396
    Burbank, CA
    Tom
    Did you get moisture inside of it? I heard it could also be the coating used on aftermarket lines to keep them from drying out. Definitely need a complete flush to resolve it.
  6. Teachdocs
    Teachdocs Formula Junior
    Sep 3, 2012
    568
    Kansas City area
    Chad
    Moisture and contaminates. Complete flush, drive, complete flush, drive.
  7. finnerty
    finnerty F1 World Champ
    May 18, 2004
    10,406
    Residual machine / tooling oil from inside the new brake lines ---- fairly normal usually left inside the lines to prevent corrosion while they are sitting in inventory.
    I typically flush new lines out before I install them to avoid this, but you will have to flush (just drain and replenish with new fluid) the system now.
    Although this is likely harmless, as it just the oil reacting with your particular brake fluid's chemistry ---- I would definitely flush to be safe.
  8. nautigirl
    nautigirl Karting
    Feb 26, 2007
    109
    Hermosa Beach
    crash
    Thanks everyone for the info. Yes it might have been from the new brake line I installed. It seemed to be less with some time. Then I did do another flush and looks good now. Looks like Finnerty should be correct.
    Thanks,
    crash
