brighter dash lights | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by bundas, Oct 15, 2013.
  1. bundas
    bundas F1 Veteran Owner
    Dec 31, 2005
    7,090
    lexington ky usa
    mitchell barnes
    I remember a thread about this. there seemed more could b done than change bulbs. please help. thanks
  2. rustytractor
    rustytractor Formula 3
    Mar 25, 2012
    1,078
    London
    Russell Schacter
    As I recall, the only other thing mentoned was to bypass the dimmer on the main dash binnacle but before doing that I'd clean it with electronic switch cleaner spray and fit new bulbs first.
    I keep meaning to do mine but never seem to get around to it.
  3. fez1238
    fez1238 Karting
    Sep 5, 2007
    170
    Hi
    When I replaced the bulbs in the dash I used a product called Stabilant - which is a military grade product that acts like a fluid solder weld and increases connectivity, electricity flow etc.
    ALSO
    If you live in the UK a dashboard light failure is now an MOT failure. !!!
    Andrew
  4. vecchio59
    vecchio59 Karting
    Nov 25, 2011
    199
    Savona, NW Italy
    Marco
    I did by-pass the dimmer and the result is ok... although, you must remember that in the 70's the light technology was not even close to what it is today... so, in a dark night, you can hardly see rev's and speed, have an idea that oil is warm... not sure you can be sure of the clock reading :)
    On the other hand, what the hell is the dimmer use ? how many times did you adjust it in the past, say, 1'000 years ???
  5. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
    On long distance over-night runs, I find that dimming the dash lights lessens eye fatigue :D
  6. vecchio59
    vecchio59 Karting
    Nov 25, 2011
    199
    Savona, NW Italy
    Marco
    fair enough :-D I'm misled by the fact that I usually drive short runs... and don't give a lot of attention to instruments... other than rev's and water temp :) !!!
  7. 400iGuy
    400iGuy Formula 3 Owner Rossa Subscribed
    Aug 26, 2004
    1,080
    Central Florida
    Al
    No matter how long you drive at night there will never be light induced eye fatigue in a 400. EVER! *<|:O)
    Al
  8. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
    No problem.
    Don't forget the oil temp.
    You're right there...with the growl of the V12 Colombo, kind of referring to dimmers in general.
  9. bundas
    Dec 31, 2005
    7,090
    lexington ky usa
    mitchell barnes
    anyone changed to LED? not seeing what is going on makes me feel very uncomfy. I drive my car long distance at night and using a flashlight is really sad.
  10. Ak Jim
    Ak Jim F1 Veteran Owner Rossa Subscribed
    Dec 23, 2007
    9,623
    North Pole AK
    Maybe you could use one of those glow sticks?
  11. bundas
    Dec 31, 2005
    7,090
    lexington ky usa
    mitchell barnes
    b nice. I could play. 'Glow little glow worm' on a CD if the car had one. But driving the Ferrari maybe, 'You light up my life'. any other suggestions?
  12. new ulm 400i
    new ulm 400i Karting
    Sep 1, 2007
    117
    Taipei, Taiwan
    Lee Atkinson
    Yeah, I went to LEDs (available on Ebay, lots of suppliers) and bypassed the dimmer. The good news, the lights are bright--the bad news, the color is quite blue. So either you should replace all the bulbs with LEDs, or get used to the fuel/temp gauges looking different...
    There is a lot of discussion on this thread for 308's, I think, so my suggestion is to look for higher brightness standard bulbs first.
  13. bundas
    Dec 31, 2005
    7,090
    lexington ky usa
    mitchell barnes
    I could use a the Cd, 'Blue Moon'. a good match.
  14. Ashman
    Ashman Three Time F1 World Champ Owner Silver Subscribed
    Sep 5, 2002
    33,257
    MA
    No suggestions but I can guarantee it wouldn't be "Blinded by the Light!" :D
  15. Ak Jim
    Dec 23, 2007
    9,623
    North Pole AK
    You guys crack me up!
  16. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
    That's the 'big' reason I won't go there :(
    +1, that's your best route, along with either cleaning the dimmer or bypassing it.
  17. galbert
    galbert Formula Junior
    Mar 14, 2012
    374
    sud ouest france
    Galbert Christopher
    bonsoir voila les ampoules leds monte sur le compte tours et le kilometrique pas sur les deux récepteurs du milieu
  18. bundas
    Dec 31, 2005
    7,090
    lexington ky usa
    mitchell barnes
    installed white. dimmer works. put in three 400ai's and my 365GT4 2+2. great results
  19. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
    Is the light white or blue, any pix :confused:
  20. bundas
    Dec 31, 2005
    7,090
    lexington ky usa
    mitchell barnes
    no photos
  21. galbert
    Mar 14, 2012
    374
    sud ouest france
    Galbert Christopher
  22. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
    Merci pour la photo (thanks for the pic) :)
