Broke mirror fix | FerrariChat
Broke mirror fix
Discussion in '348/355' started by taz355, Feb 21, 2013.
  1. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    I was backing into my garage and hit the pass side mirror and broke it off. I know. I know. Anyway after removing mirror and marking and pushing out pins from plug I bought a stainless nut the same size as mirror nut. Threaded nut on carful and tighten it slowly trying to use the nut as a thread cutter. I managed to cut two compleat threads. I cut the spring by about quarter inch checked the nut which now had three and a half threads instead of four originally reinstalled and everything works and morrow still cams foreword and backward. 1500 saved if pass side and 4500 saved if drivers side. I am now not quite so upset. Grant
  2. RSO1091
    RSO1091 Formula 3
    Mar 31, 2012
    1,547
    Idyllwild, CA.
    Henry S.
    My lips are sealed about the windshield incident...
  3. Extreme
    Extreme F1 Rookie
    May 26, 2010
    2,515
    Northern Utah
    Erick
    Ouch! It takes a big man to admit his errors...
    Good job on the stooge repair. :)
  4. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Thanks Henry i
