Buy
Broken 308 air injection cut-off valve
Discussion in 'Technical Q&A' started by Doc, Dec 26, 2003.
  1. Doc
    Doc Formula Junior
    Sep 13, 2001
    886
    Latham, New York
    Bill Van Dyne
    Well, par for the course, while changing out all of the vacuum hoses on my car, an '85 308, the plastic nipple broke off of the cut-off valve ( that round plastic thing located above the clutch housing w 2 large air hoses and a vacuum line attached to it). Does anyone know about what these things cost or if there is a Fiat, GM, etc part which would fit?
  3. ferrarioldman
    ferrarioldman Formula 3
    Jun 19, 2002
    1,027
    Summerfield, NC
    Tom Jones
    Doc, an easy repair is to take the valve out and install a small piece of metal tubing for the nipple. You may have to drill the plastic out a bit to fit the OD of the metal tube plus a little super glue. Or you could even use a part of a plastic vacuum line splice that you can get at any parts house.
  4. Sophia
    Sophia Formula Junior
    Aug 17, 2003
    298
    Dash Point/Federal W
    Peter Barbin
    Doc, Check GM, late 70's/early 80's. I'm on the road, so I don't have my cross-reference handy.
