Broken bracket on 430 Top replacement | FerrariChat
Discussion in 'Ferrari Discussion (not model specific)' started by FloridaToAtlanta, Jan 29, 2019.
  1. FloridaToAtlanta
    May 30, 2018
    43
    Atlanta Georgia
    Matt
  2. Bob in Makiki
    Bob in Makiki Formula Junior
    May 30, 2017
    455
    Honolulu
    I'm not clear on where this is. If this is the cable that supports the fabric wing behind the seats, then as far as I know, no one has found a source for just the metal part. (I have just had one such cable replaced, and the other is going in to be replaced in two weeks.) If it is another cable, then I don't know. There are a number of good threads in the 360/430 forum on the tops (they are the same for both models) and you might find more good information by searching there. Good luck!
  3. FloridaToAtlanta
    May 30, 2018
    43
    Atlanta Georgia
    Matt
    Thanks Bob. That’s the correct cable. Did you have the dealer replace it or is there a place to get one online?
  4. Bob in Makiki
    May 30, 2017
    455
    Honolulu
    The cables are easy to get and the 360 Forum has several good threads with pictures showing how to replace it yourself, should you want to give that a try. The cable is the "Upper Finned Pocket Stretch Cable", and is part no. 66375800. Here is a link to the part:
    https://www.ricambiamerica.com/66375800-upper-finned-pocket-stretch-c.html
    Having said that -- I took it to the dealership and they sublet the job to a local upholstery shop. I knew the shop that did the work well (having had a couple of other cars refitted there), but I wanted the dealership to oversee the work. As it happened, there were some little things that needed to be addressed after the work was done, and the dealership took care of that.
    Good luck!
