Broken Cam Belt Cover | FerrariChat
Discussion in 'Technical Q&A' started by RWDOMKR, Mar 2, 2005.
  1. RWDOMKR
    RWDOMKR Karting
    Aug 18, 2004
    97
    Stockton, CA USA
    RWDOMKR
    Hi guys...pulled the cam belt covers off of my GT4 last night and found that the forward cover is missing a bit of its edge near the crankshaft pulley - I believe it was ripped when the previous owner lost a belt. Doesn't affect the integrity of the cover other than there is about a 2-inch square area of belt protection exposed - thoughts?? Thanks for your input.
  2. Rifledriver
    37,332
    A belt failure cannot do that. Are you sure it is not around the waterpump area? It used to be a common form of butchery to cut or break off the part overlapping the waterpump in the early cars that were put together with studs instead of bolts.
  3. RWDOMKR
    RWDOMKR Karting
    Aug 18, 2004
    97
    Stockton, CA USA
    RWDOMKR
    Brian - I am positive you're right on the mark....thank you!!
  4. Rifledriver
    37,332
    I would not lose sleep over it unless you don't like the looks of it. If that is the case you can probably get one used from T Rutland.
  5. RWDOMKR
    RWDOMKR Karting
    Aug 18, 2004
    97
    Stockton, CA USA
    RWDOMKR
    Great...thanks again!!
  6. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    Mine had been cut rather crudely in the same area for the same thing on my 308. I took an air grinder and cleaned it up a bit. Looks better!
    Birdman
