Broken coolant pressure cap | FerrariChat
Discussion in '360/430' started by Whitby, Dec 30, 2016.
  1. Whitby
    Whitby Rookie
    Jul 12, 2015
    5
    Florida
    I am sure this has been a thread in the past but maybe worth a review.
    After Mondiale Finale I had terrible overheating and seemed to be loosing coolant.
    After mild panic and then some thoughtful checking I suspected the cheap plastic cap on the expansion tank. I had the dealer do a pressure check and replace the cap - problem fixed.
    Here is the warning! As I have never had any cooling issues in 12 years and 22k Miles I rarely check the coolant. I had blown out almost all my coolant (5litres) and was probably very lucky I did not do any serious damage. The stupid cap is $50 and in hindsight I should probably just have replaced it years ago. I will probably buy a spare and write myself a note to replace the cap again 5 years from now so I don't risk an expensive problem
  2. Rifledriver
    37,114
    They are junk. I buy them by the bag full and their average life before failing a pressure test is 2 years. I test them at every annual service.
  3. shad99
    shad99 Formula Junior
    Dec 12, 2013
    300
    Japatul Valley, CA
    Andy
    I've bought them on eBay. Same part for about $10.
  4. BladeMD
    BladeMD Formula 3
    1,140
    Sarasota, FL
    Hannibal
    Great to know! Thanks for the heads up! (Added to list of things to check this winter)
  5. vrsurgeon
    vrsurgeon F1 World Champ
    16,544
    Charleston, SC
    Curt
    Cheap part. Plastic and rubber degrades with the heat. I bought an extra on eBay for like $15 bucks and put it on. I'm going to just keep an eye on things and if I hear any buzzing sounds (pressurized air escaping) from the cap after a drive its getting replaced.
  6. Zanny1
    Zanny1 Formula 3
    1,139
    Arizona
    Just had 30K service done on my 1999 Modena. Shop replaced the cap, and said they generally do this every 2 years as the caps leak/fail. Cheap insurance. I think the cap was about $20.
  7. I'm 360 Canuck
    I'm 360 Canuck Formula 3
    Nov 21, 2015
    1,911
    Ontario, The Real One in Canada
    Lars!
    Good info. Thanks.
  8. hessank
    hessank Formula 3
    1,933
    Canada, Florida
    Fred
    I bought a spare from Daniel (Ricambi) 2 weeks ago to carry around as a spare. I am now going to install it instead. Thanks for the heads up.
  9. BladeMD
    BladeMD Formula 3
    1,140
    Sarasota, FL
    Hannibal
    #9 BladeMD, Mar 31, 2017
  10. BladeMD
    BladeMD Formula 3
    1,140
    Sarasota, FL
    Hannibal
    #10 BladeMD, Mar 31, 2017
  11. RedNeck
    RedNeck F1 World Champ
    12,343
    The CSA
    Me
    This one. I just replaced mine, was $50 from Ricambi. Not sure about the $10 ones, maybe someone can post a link?
  12. BladeMD
    BladeMD Formula 3
    1,140
    Sarasota, FL
    Hannibal
    Thanks Matt! Didn't see any on ebay for less than $50 either
  13. vrsurgeon
    16,544
    Charleston, SC
    Curt
    LOVE the metal cap. Totally fits the 80's Chevy radiator look. :) Chikka chikka bow bow..
    Edit: looks like the cheap chinese $15 knockoffs aren't on ebay anymore.
  14. Under PSI
    Under PSI F1 Rookie
    May 13, 2005
    4,240
    Phoenix
    Jim
    I've gone through at least 3 of them.
  15. Rifledriver
    37,114
    The only alternate I found was for Alfa Romeo. One would think they used the same vendor but they do not and so many failed to hold pressure right out of the box I gave up.
  16. BladeMD
    BladeMD Formula 3
    1,140
    Sarasota, FL
    Hannibal
    Brian, are you finding better longevity with the Ricambi part now (assuming that's what you're using)?
  17. vrsurgeon
    16,544
    Charleston, SC
    Curt
    Irregularity in the rubber seal or defect in the spring seating? I guess I got lucky.. the cheapie actually works in the heat! Thank you for the update on the possible alternative part.
    I guess its ricambi if we need one.. maybe I'll try awitalian..
  18. f355spider
    f355spider F1 World Champ
    18,047
    Over the ten years I owned my F355 spider, I went through three caps... I bought one from Ricambi, but was surprised to see them offered on Ebay from awitalian for around $35 delivered. But that was 4 years ago for the last one...don't see them that cheap now.
