broken front window 3500gt | FerrariChat
Discussion in 'Maserati' started by 3500GT1336, Apr 10, 2017.
  1. 3500GT1336
    3500GT1336 Rookie
    Jan 2, 2017
    5
    Netherlands
    Gerard Swaen
    About three weeks ago I discovered a crack in the front window of my 3500gt, with no apparant cause. The window was replaced by a notable window repair company. The crack in the window was on the inside, exactly at the point where one of the threaded ends of the chrome trim went through the window rubber. The expert who replaced the window had noticed this and he suspected it to be cause of the crack. In order to prevent this from happening again he had placed a small piece of hard plastic (a spacer they frequently use) over the bottom threaded ends so the window would not directly rest on one of these.
    So, any reader with a broken front or back window that has trims fixed throught the rubber with threaded ends a suggestion would be to protect the new window from directly resting on one of the threaded ends.
    By the way, the new window was just as expensive as purchasing one myself, but now the new window has a life long guarantee against production faults or placement faults and placing it was not at my own risk
    Gerard
  2. Portenos
    Portenos Formula 3
    Aug 20, 2004
    1,853
    Seattle
    Carguytour
    Great tip. Thanks much.
    FGM
