Broken Gasket -> Oil Leak | FerrariChat
Discussion in '360/430' started by MAQ, Feb 27, 2014.
  1. MAQ
    MAQ Rookie
    Jul 3, 2013
    32
    I had a significant oil leak, and brought it to mechanic. Turns out the gasket is broken. It's a $66 part, but a large portion of the engine has to be taken apart to replace it yielding a massive estimate of $6500. Mechanic is a Ferrari specialist, but said he had never seen this in an F430. I have a 2006. Just curious if this happened to anyone else. Thanks.
  2. vrsurgeon
    vrsurgeon F1 World Champ
    16,543
    Charleston, SC
    Curt
    Where was it? Crank seal? Cramshaft seal? Oil pump?
  3. cfoster32
    cfoster32 Karting
    Nov 15, 2010
    131
    Cedar Rapids, IA
    Cody Foster
    Valve covers ?
  4. MAQ
    MAQ Rookie
    Jul 3, 2013
    32
    I'm not sure which seal it was. He explained that a good chunk of the engine had to be removed to get to the broken gasket. I believe he said the valve covers had to be removed to make the repair. A significant amount of oil was coming out.
  5. calder1
    calder1 F1 Rookie
    Sponsor Owner
    Aug 26, 2006
    2,922
    Redondo Beach
    Craig
    I have the car, there is a section of the front timing cover gasket that has been "blown out" not seen anything like this on any other 430 we have serviced before, but it causing a significant leak. The car was down 2 quarts when it came in. Anyone else experienced this ?
  6. FerrariDublin
    FerrariDublin F1 Rookie
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    That's a lot of oil loss. I'm interested to learn more about this.
  7. vrsurgeon
    16,543
    Charleston, SC
    Curt
    Interesting. Defective gasket perhaps? Following with interest as well..
  8. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
    Got any pics that we can see?
  9. calder1
    calder1 F1 Rookie
    Sponsor Owner
    Aug 26, 2006
    2,922
    Redondo Beach
    Craig
    Yes, will post shortly
  10. calder1
    calder1 F1 Rookie
    Sponsor Owner
    Aug 26, 2006
    2,922
    Redondo Beach
    Craig
    #10 calder1, Feb 28, 2014
  11. vrsurgeon
    16,543
    Charleston, SC
    Curt
    #11 vrsurgeon, Feb 28, 2014
    Oh that IS a pain to get at isn't it... :(
    How many miles? Almost looks like a manufacuturing error. Pinched/ill placed gasket. Gasket 21? PCV issue? Interesting.
  12. Ricambi America
    Sponsor Owner
    They were superseded several times since introduction. I'm not surprised it broke, if that is original to the car.
  13. calder1
    calder1 F1 Rookie
    Sponsor Owner
    Aug 26, 2006
    2,922
    Redondo Beach
    Craig
    Yes gasket 21,
  14. MAQ
    MAQ Rookie
    Jul 3, 2013
    32
    17,000 miles. Thanks for the pictures Craig.
  15. FerrariDublin
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    Upsetting how the smallest of things can cause such heartache. A fair bit of tear-down required to get to that I imagine ........ and then of course there's the "while we're in there" scenario.
    I feel for ya MAQ!
  16. windsock
    windsock Formula 3
    1,153
    Actually fairly common. Proper repair requires head gasket and front cover gasket replacement. Any shops will just pull the front cover and fill the void with high quality silicone sealant. Your current estimate is inline for the repair.
  17. brian.s
    brian.s F1 Rookie
    Nov 3, 2003
    3,809
    Midwest
    Brian
    Yes, seen a couple, also one Maserati front cover gasket too. Also had one fail after an engine redo, it needs careful assembly plus some sealant at the ends of the gasket. Since the fail point is on a horizontal plane the oil tends to pool there anyhow.........It's a large cover to install, plus being very careful with the front crank seal at the same time.
  18. BT ZR1
    BT ZR1 Karting
    Nov 22, 2013
    123
    Toronto
    Every time I get close to talking myself into one of these cars I read something like this. Like a cold shower.
