Broken Schrader valve & missing fuse? Help... | FerrariChat
Discussion in '348/355' started by ghardt, Sep 14, 2013.
  1. ghardt
    ghardt Formula 3
    Apr 18, 2004
    1,260
    Texas
    Jerry
    #1 ghardt, Sep 14, 2013
    1993 348
    AC Schrader valves have been leaking for a while now. So I decided to remove and replace, but both the high side and low side valve broke in half and left valve portion still in the hose fitting. 1st photo shows broken Schrader valves. 2nd photo shows AC fitting with the lower portion of the broken valve still in place.
    1.) Is there a tool to remove the remainder of the valve core, or can someone give me some advise, please?
    2.) Any other suggestions?
    3rd photo shows a bank of relays next to the AC evap housing on the passenger side, but the first relay appears to be missing a fuse.
    3.) Should there be a fuse there? What is that relay for? amp size?
    Thanks,
    Jerry
  2. GTO Joe
    GTO Joe Formula 3
    1,002
    Charlotte, NC
    Joseph Troutwine
    Don't worry about the fuse, it is suppose to be empty. It is there to put a fuse in to check the operation of the ABS system if there are problems. For the valves, I would take it to an AC shop because I am sure they face this on a regular basis and have a special tool to get them out. Good luck.
  3. ghardt
    ghardt Formula 3
    Apr 18, 2004
    1,260
    Texas
    Jerry
    #3 ghardt, Sep 14, 2013
  4. ghardt
    ghardt Formula 3
    Apr 18, 2004
    1,260
    Texas
    Jerry
    Thanks for the info on the ABS fuse.
  5. GTO Joe
    GTO Joe Formula 3
    1,002
    Charlotte, NC
    Joseph Troutwine
    Great! Glad it worked out for you. I thought about the easy out after I posted but was reluctant to repost and recommend given the soft metal involved. Those valves are usually not in very tight so I think that may have helped.
  6. Bucci
    Bucci Karting
    Jan 5, 2020
    79
    Mark Bucci
    Not sure how you got the small tip out as well as the housing as the tip is not connected to the housing and generally falls into the line. Did you get both or just one?
  7. PAP 348
    Dec 10, 2005
    100,219
    Mount Isa, Australia
    Pap
    He used an Ezi-out by the looks and got them both out. :)
