BSM coil overheating, quick fix | FerrariChat
Discussion in '206/246' started by alhbln, Oct 4, 2009.
  1. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,749
    Berlin, Germany
    Adrian
    For anyone who uses a BSMpdi electronic ignition installed in their Dino and found that the coil is getting quite hot after a while, here is a fix.
    The coil included in the setup is a Bosch TCI coil (0 221 122 334 as example), the operation parameters by Bosch are specified at 8.0 ampere max current and 4.8 ms max dwell.
    The default (custom) parameters in the BSM setup are 10.0 ampere with a max dwell of 6.2 ms, this drives the coil in saturation which in turn will create a lot of heat. Change the setting in the BSM control software to 8.0 A current and 4.8 ms, and the coil will get warm but not hot, while retaining the full ignition power.
  2. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,202
    Norfolk - UK
    Tony
    Great work Adrain, i just knew these settings were all wrong but never got around to changing them.
    I will give it a go and report back any problems.
    tony
