BSM Ignition. Unavaliable??? | FerrariChat
Discussion in '308/328' started by GavC, May 11, 2012.
  1. GavC
    GavC Formula Junior
    May 9, 2004
    492
    Lincolnshire, Englan
    Gavin Culshaw
    Just when I have decided to take the plunge and buy a BSM Ignition kit from Superformance. I was told by them on backorder from BSM in Aussie and no idea when they will be getting any. I have tried to contact them direct and as yet no reply. Apparently there is a problem with none supply!! Any body know whats happening or where there are any kits avaliable. wanting a single dissy model for a 77 308gt4. Thanks
  2. Perfusion
    Perfusion F1 Rookie
    Oct 16, 2004
    4,151
    Marietta, GA
    Aaron
    Try Carobu Engineering in California - they carried them at one time...may still.
  3. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,749
    Berlin, Germany
    Adrian
    There seem to have been some structural changes at BSM and I think I heard that the guy who builds the pdi ECUs for BSM is not doing that anymore. Anyway, give Colin at Superformance a call, he knows them quite well and should be able to give you some more infos.
    Good luck,
    Adrian
  4. GavC
    GavC Formula Junior
    May 9, 2004
    492
    Gavin Culshaw
    Spoken to Colin and know the full story, which I won't comment on here. It looks like this system is now no longer avaiable until the situation is resolved or someone else designs an alternative. Now stuck as wanted to add this electronic system to the car after speaking to people who have had it fitted with good results.
  5. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,749
    Berlin, Germany
    Adrian
    A possible alternative would be to lock out the advance mechanism in your dist and to install a MSD 6530. This approach is similar to a BSMpdi setup as it keeps the dist to deliver the spark to each cylinder but manages the advance timing via a programmed advance curve.
  6. thecarreaper
    thecarreaper F1 World Champ
    18,053
    Savannah
    I used Crane hall-effect ignitions in 2 of my carb cars, one a series one GT4 with great results.
  7. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,749
    Berlin, Germany
    Adrian
    BSMpdi is not just a ignition seutp, but an ECU which replaces the advance weight mechanism against two selectable programmable curves, so you don't need to set up your dist on a distributor tester anymore and can program the curve on a rolling road instead.
  8. BigTex
    79,368
    Houston, Texas
    Bubba
    Greg328 has a Nick's electronic system NewInBox for sale, last time I spoke with him..
  9. GavC
    GavC Formula Junior
    May 9, 2004
    492
    Gavin Culshaw
    Still seems that the BSM ignition kit isw not avaiable. has anyone done this conversion. Lock out the advance mechanism in your dist and to install a MSD 6530. This approach is similar to a BSMpdi setup as it keeps the dist to deliver the spark to each cylinder but manages the advance timing via a programmed advance curve. This is what alhbln has suggested. I liked the BSM as it looked original with a more modern distributor and a programmable ECU which could be hidden in the boot.
  10. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,749
    Berlin, Germany
    Adrian
    I heard from Tim at Black Stallion that they are developing a new version of the BSMpdi ignition controller so looks like they are still active and getting back in the game.
  11. VEEP
    VEEP Formula Junior
    Nov 9, 2005
    525
    Overasselt
    for dutch Ferraristi with the same problem: BAS autoservice Lichtenvoorde and ONIXX also in Lichtenvoorde builds distributors with build in programmble ecu for the advance. They set the up on the dyno, so custum for every car. Cost will be aprr. be the same or even cheaper as the BSM, if your distributor is in good order , and maybe still if it needs a rebuild.
  12. Aircon
    Aircon Ten Time F1 World Champ
    100,524
    Melbourne, Australia
    Peter
    Correct. Had the distributor installed today. Should be up and running next week.
  13. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,749
    Berlin, Germany
    Adrian
    Haven't heard from Tim for a long time, good to know they are back in the business. Could you post a photo of the new setup?
  14. Aircon
    100,524
    Peter
  15. maurice70
    maurice70 F1 Rookie
    Jan 25, 2004
    4,334
    maurice T
    See Pete,I knew I wasn't imagining it :D
  16. Aircon
    100,524
    Peter
    Indeed. I'll tell Tim tomorrow. He'll be surprised too.
  17. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,749
    Berlin, Germany
    Adrian
    I don't think they went out of business per se but they stopped making and selling BSMpdi's, at least to customers outside of Australia. Both Colin @Superformance and myself tried to get into contact with Tim for quite some time now but haven't been successfu. My last mail exchange with Tim was somewhere in 2010. Delta Digital/Einstein, the original maker of the BSMpdi supplied ECU, does not seem to be in business anymore so it looked like BSM would have stopped selling the BSMpdi setup.
    The setup in the link above looks like the standard BSMpdi distributor with the Bosch cap, would be interesting to find out if they now have a new supplier for the ECU. Could you post a photo of the ECU?
  18. Aircon
    100,524
    Peter
    The original system is still very much available and being sold.
    I've got the old system installed temporarily until the new system comes on line soon. I had it in a previous 308 and it made a huge difference. The update, which I get it, will be even better again.
  19. The Kook Abides
    The Kook Abides F1 Rookie
    Jan 4, 2011
    3,459
    Leave it stock and set it up properly...
    It's a classic car. My car runs like a bat out of hell with the original ignition.
  20. Aircon
    100,524
    Peter
    You say that without the full knowledge I have, if you think that gives the same result.
