Bugatti Bolide Track Only Car | Page 4 | FerrariChat
Discussion in 'Bugatti' started by Jonathan19, Aug 11, 2020.
  1. Jonathan19
    Jonathan19 Formula 3
    Sep 13, 2017
    1,346
    France
    Jonathan
    BUGATTI presented the BOLIDE in late 2020 – a daring vision focused on a lightweight, track-only hyper sports car delivering an incomparable driving experience built around the brand’s iconic W16 engine. Since August 2021, when BUGATTI confirmed at The Quail, A Motorsports Gathering, its plans to commence series production of the BOLIDE, intense development has been taking place.
    Scuderia CC likes this.
  2. Jonathan19
    Sep 13, 2017
    1,346
    France
    Jonathan
    BUGATTI BOLIDE ENTERS NEXT PHASE OF TESTING!
    When the Bolide was first revealed as a thought experiment in late 2020, it presented a vision of a lightweight, track-only hyper sports car delivering incomparable performance, built around the iconic W16 engine. That ambitious dream is being transformed into reality, as the Bolide prototype begins its next phase of development testing.
    At The Quail, A Motorsports Gathering in August 2021, Bugatti announced that the Bolide1 would be developed for a limited production run of just 40 units. Centered on the premise of creating the ultimate track-only Bugatti and set to be the most uncompromising model to ever emerge from Molsheim, it represents an entirely new level of engineering, aerodynamic and technological innovation.
    For the Bolide, Bugatti started with the quad-turbo W16 engine, and then built the lightest possible car around it. Its minimal bodywork is designed carefully to leverage maximum downforce, most efficient cooling and exceptional power-to-weight ratio. In its final form, the Bolide is expected to deliver 1,600 PS and a dry weight of only 1,450 kg to better the magical 1:1 ratio.
    Christophe Piochon, President of Bugatti Automobiles, said: “The Bolide is treading new ground for Bugatti. Never before has such a powerful engine been paired with an ultra-lightweight design to create a track car that delivers motorsport levels of performance. Almost every component has been analyzed and redesigned to ensure Bolide is as light, capable and reliable as our strict targets require it to be. The next phase of development is a major milestone in the creation of a car that takes Bugatti’s “form follows performance” philosophy to a new level.”
    Creating the Bolide is a case of bespoke craftsmanship. Although the engine may be familiar in its layout and capacity, it is integrated into the Bolide in a fully different way. A newly shaped carbon monocoque compared with Chiron2 meant re-engineering many components, including cooling, transmission and suspension, each of which now had to be packaged within the incredibly compact and aerodynamic design of Bolide, with a matter of millimeters to spare. With new engine mountings, the suspension of Bolide’s drive unit is three times stiffer than the Chiron’s. Together with the uniball suspension bearings, the Bolide gives the driver even more precise feedback. The Bolide also uses 3D-printed titanium rockers to help create intricately shaped and lightweight components.
    The engine itself is central to the Bolide experience, but subtly adapted for this car’s unique character. It always operates on all four of its turbochargers – perfect for the racetrack where engine revs are consistently high, but also for weight and packaging reasons. The team has tuned the engine to deliver higher revs per minute and successfully paired it to a modified transmission designed to deliver even sharper performance.
    The braking system offers entirely new levels of performance and innovation. In the Chiron, the brakes are an effective and long-lasting carbon ceramic system but the Bolide uses even more heat-resistant carbon-carbon brakes. These must be thoroughly warmed before they reach their peak effectiveness so Bugatti engineers designed completely new calipers that would more efficiently generate and absorb heat. With 18-inch tires, 390 mm brake discs were created and a carbon cover placed on each wheel to help protect the rims from the extreme heat generated by the brakes.
    Befitting its status as a track car with the performance of a top-level motorsport machine, the Bolide is fitted with slick tires which – at the rear – can only be found on LMDh vehicles racing in the FIA World Endurance Championship. Thanks to tire manufacturer Michelin’s long-standing partnership with Bugatti, these tires can be used for the Bolide.
    First deliveries of the Bolide will commence in 2024, with production limited to just 40 units at a net unit price of four million euros each.
  3. Jonathan19
    Sep 13, 2017
    1,346
    France
    Jonathan
  4. Jonathan19
    Sep 13, 2017
    1,346
    France
    Jonathan
  5. willcrook
    willcrook F1 Rookie
    2,577
    the only problem is it's an extra 200kg or so heavier than the original concept and has around 200hp less power iirc
  6. Jonathan19
    Sep 13, 2017
    1,346
    France
    Jonathan
  7. Jonathan19
    Sep 13, 2017
    1,346
    France
    Jonathan
  8. Scuderia CC
    Scuderia CC Formula Junior
    Nov 1, 2003
    520
    France
    Christophe
    it's promising. The forty lucky buyers will not be bored.
    Jonathan19 likes this.
  9. BJK
    BJK F1 Veteran
    Jul 18, 2014
    5,343
    CT
    #84 BJK, Jan 7, 2025
    Manny Khoshbin - delivery and start-up (note skinny 'delivery' tires @ 2:44)
  10. BJK
    BJK F1 Veteran
    Jul 18, 2014
    5,343
    CT
    #85 BJK, Jan 7, 2025
    on-track at COTA ...... crap :rolleyes: :(
  11. Tenney
    Tenney F1 Rookie
    Feb 21, 2001
    4,261
  12. Jonathan19
    Sep 13, 2017
    1,346
    France
    Jonathan
  13. Christian.Fr
    Jun 9, 2005
    21,354
    Christian.Fr
    the BOLIDE is the ultimate expression of BUGATTI performance.
    Scuderia CC and Jonathan19 like this.
  14. Scuderia CC
    Nov 1, 2003
    520
    France
    Christophe
  15. amenasce
    34,276
    Joe Mansion
    So did those numbers come true? 500kmh? and 5mn Nurburgring lap time?
  16. Jonathan19
    Sep 13, 2017
    1,346
    France
    Jonathan
    I hope Bugatti will try these numbers.
