Building a Caterham | Page 3 | FerrariChat
Building a Caterham
Discussion in 'British' started by sainthoo, Jul 21, 2020.
  1. sainthoo
    sainthoo Formula 3
    2,055
    Christian
    Thanks!
    Virginia- there is a specific regulation for assembled kit cars, so here is hoping I don’t need a lawyer when the time comes. They don’t seem to care about build- just proof of ownership.
    Ah the Atom… mine was never street legal, nothing quite like that thing.
    Smiles likes this.
  2. Smiles
    Smiles F1 World Champ
    Nov 20, 2003
    16,673
    Pittsburgh, PA
    Matt F
    The two cars I regret selling most: my 330 and my fully equipped Brammo Atom 2.
    Matt
    sainthoo likes this.
  3. JL350
    JL350 Karting
    Jan 20, 2013
    211
    Those tyres must have been a bit sketchy in the rain:D
  4. sainthoo
    sainthoo Formula 3
    2,055
    Christian
    There was a rain tire- racing in the rain was just plain scary 90% of the time. Zero visibility from spray and very unforgiving balance…. Don’t miss that at all.
    JL350 likes this.
  5. sainthoo
    sainthoo Formula 3
    2,055
    Christian
  6. sainthoo
    sainthoo Formula 3
    2,055
    Christian
    Been a long pause. Big step- got motor in today.
    So far, spending more time trouble shooting directions/ figuring out how to build it in a better order than directions and searching for the proper hardware (I would guess by the end I’ll have 1/2 of hardware left over).
    Can’t overstate this: if you consider it, buy from Rocky Mountain Caterham, because they are super helpful working out problems.
    j09333 and Dolcevita like this.
  7. sainthoo
    sainthoo Formula 3
    2,055
    Christian
    Well, I’m supposed to install exhaust headers- before- installing dry sump (happily that was only sitting in place as I am sorting out finding some hardware to attach it to frame). So, out goes the sump, on goes the headers.
  8. sainthoo
    sainthoo Formula 3
    2,055
    Christian
    Had a day off, so I tackled the rear suspension, got it done.
    As seems to be customary- I seem to spend more time finding parts/ figuring out what to do as actually doing things.
    Roll cage had to go in first (despite being multiple, multiple pages later in the build manual); if you don’t install cage first, you would have to take off rear damper to get it in (no access to mounting bolt with damper installed).
    1) I have still not sorted out exhaust header problem.
    2) I have the wrong lug socket (despite ordering the 41mm socket as told- suspect it is 43mm).
    audi_328 likes this.
  9. 356racing
    356racing Formula Junior
    Sep 24, 2004
    541
    Paradise Valley, AZ
    43mm would be an odd size for the axle nut, or any nut for that matter. Almost every axle nut I’ve encountered has been 36 or 42. Not saying it couldn’t be 43 but measure to be sure.
  10. sainthoo
    sainthoo Formula 3
    2,055
    Christian
    You are correct - just got an email back from Josh at Rocky Mountain Caterham- it’s a 42mm (once again- to anyone considering a build, buy from these guys!)
  11. sainthoo
    sainthoo Formula 3
    2,055
    Christian
  12. sainthoo
    sainthoo Formula 3
    2,055
    Christian
    Left to do, in no particular order:
    Front wing fenders - glued in place- going to have to be very deliberate with measurements and looking carefully.
    Rear fenders- these bolt on.
    Electrical, including filling battery with acid (not something I relish- almost enough for me to go get a light weight lithium ion…)
    4 point harnesses, seats
    Interior trim
    Brakes- bit of line, bleeding
    Top off fluids
    Quite concerned about trying to put the steering wheel on straight, as I have to drill the darn thing to fit hub… if I’m off even a tiny bit, I’ll know, even if no one else does.
    And…. Those exhaust headers before I can fit up the rest of the exhaust.
    JL350 likes this.
  13. sainthoo
    sainthoo Formula 3
    2,055
    Christian
    Discovered a new problem… the driver’s side axle nut was delivered with edges somewhat proud. Quite odd- filed down the edges to get the 42mm socket on the nut. The passenger side was no issue.
    Just plain weird.
  14. sainthoo
    sainthoo Formula 3
    2,055
    Christian
    Today: tried everything I could think to do to adjust engine position, all to no avail.
    Fitted accelerator cable, tightened oil lines, fitted rear fenders and lights.
    throttle cable- had to remove airbox/air intake to access pedals more easily (at first I did t even realize this was possible - so I was contorting myself into the driver’s footwell). Adjusted back stop to pedal, adjusted cable position to allow tiny amount of slack for throttle application to be a bit more gentle.
  15. sainthoo
    sainthoo Formula 3
    2,055
    Christian
    Rear finders required cutting them… not something I was excited to tackle. As I have the “R” kit and my control arms are in the lower of 2 positions, I have to notch around the lowest of the holes to clear the control arms.
    As is the case with such things, the second attempt was a bit more up to snuff (guess which one I am sharing now?).
    Then, trim is cut and notched to follow the counter of the fender.
  16. sainthoo
    sainthoo Formula 3
    2,055
    Christian
    LVP488 likes this.
  17. sainthoo
    sainthoo Formula 3
    2,055
    Christian
    Another day off, more progress- tunnel carpet, harnesses, rear wing protective panels, some interior riveting/trim, fitted fuel filler cover and washer bottle with rear carpet.
  18. sainthoo
    sainthoo Formula 3
    2,055
    Christian
  19. sainthoo
    sainthoo Formula 3
    2,055
    Christian
  20. sainthoo
    sainthoo Formula 3
    2,055
    Christian
    #70 sainthoo, May 5, 2022
  21. sainthoo
    sainthoo Formula 3
    2,055
    Christian
    Comic factory attempt to drill through the aluminum support rod at the front edge of the boot cover- had to remove this to open up holes…. Yes, the holes are still not big enough / aligned over the anchor points for the harnesses (got out the Dremel, made them even larger, good grief- I guess most people will never see this?)
    Last pic- harnesses installed, support back in boot cover which is installed.
  22. sainthoo
    sainthoo Formula 3
    2,055
    Christian
  23. sainthoo
    sainthoo Formula 3
    2,055
    Christian
    Another day off- basically done.
    Installed floor mats, seats. The composite seats with contrast stitching are great.
    Final big job was front fenders- these are glued on to the “ wing stays.” No great way to align them- they seemed a bit “akimbo” from out of the mall LT. Eyeball, some cardboard spacers, bead of glue and fingers crossed.
    EarlyCat, LVP488 and SVCalifornia like this.
  24. sainthoo
    sainthoo Formula 3
    2,055
    Christian
    EarlyCat and JL350 like this.
  25. sainthoo
    sainthoo Formula 3
    2,055
    Christian
