Building New Garage for Ferraris | Page 3 | FerrariChat
Discussion in 'Ferrari Discussion (not model specific)' started by Morgie, Jan 3, 2006.
  1. sandersja
    sandersja Formula Junior
    Jan 16, 2003
    367
    Portland OR
    John Sanders
    #51 sandersja, Jan 7, 2006
    From the extremely impressive garage-mahals posted here, I seem to have gone for a different concept. While it would be nice to have a nicely decorated clubhouse, I tried to construct an efficient working environment for playing with cars.
    What started me thinking about this is that I offer a suggestion to have lots of pegboard on the walls. While the look sucks relative to laser cut cavallinos and Ferrari flags, it is extremely convenient for hanging up all the bits and pieces.
    I also second (+) the suggestions for lots of outlets (on different circuits) along with tons of lights.
  2. stevehuck
    stevehuck Formula Junior
    Jun 4, 2004
    331
    Sterling Hgts, Mi
    Steven Huck
    No! It's a plug that is recessed in the wall where you plug in a clock to tell you what time it is.
  3. Morgie
    Morgie Formula Junior
    May 3, 2005
    435
    SF Bay/Carmel
    duhh! thanks for the clarification
  4. bobafett
    bobafett F1 Veteran
    Sep 28, 2002
    9,193
    Alex: good idea on the L shape for the garage doors. Must make the building MUCH more versatile.
    --Dan
  5. 410SA
    410SA F1 Veteran
    Nov 2, 2003
    8,511
    West Coast
    A
    The configuration possibilities are very good. I can get 6 cars in what really pencils out as a 4 car space. because cars can be moved in E-W or N-S
  6. ultgar
    ultgar Karting
    Nov 21, 2003
    126
    New Jersey
    Steve D'Gerolamo
    I've consulted on quite a few high end garages for collectors and enthusiasts over the years. The nicer projects have 3 different garage areas....one dedicated as a showroom/museum , one for service & detailing, and one for the daily drivers.
    My approach is to engineer the technology into the space and integrate it into the interior design. The cars are the stars here....elaborate paint schemes on the floors and walls will detract from that.
    Here are some must-have's for serious garages........
    Radiant heat - I prefer Munchkin, Buderas or Viessmann boilers
    Wall Mounted Split A/C units - 2 to 3 units at various locations in a large shop
    Rotary Screw Compressor with cycling drier and proper filtration -
    100-200a power including digital 3-phase for the compressor, electromechanical lifts and large machining or woodworking equipment .
    Rack mounted equipment - for audio, video, security and controls - Middle Atlantic
    Lifts - single post parking lifts 2 post electromechanical service lifts, and flush mounted scissors lifts
    Cameras - inside and out
    Clean Agent fire suppression systems
    Ventilation & Fume extraction
    Humidity control systems (independent of the AC)
    Lighting - mix of T5/T8 linear and MR16 halogen for general and task applications. Direct and indirect. Some LED or fiberoptic for color
    Flooring - tile in the museum area, epoxy in the workshop
    Walls - washable paint, tile or FRP
    Storage & Workbenches - Lista
    Switches & Outlets - Hubbell or Pass & Seymour (5362A)
    etc etc etc.
    You can see a bit of this on my website at http://www.ultimategarage.com/UltGar2y.htm . You can contact me directly if you need assistance with your project. Steve
  7. Challenge64
    Challenge64 F1 Veteran
    6,367
    Ron
    #57 Challenge64, Jan 16, 2006
    This is my 1200 sq/ft guest house. It holds 2 cars...
    plus
    - office in same room as 2 cars
    - AC/sat/cable/internet...ect
    - full kitchen & bar
    - full guest suite & bath
    - glass doors are top hung bi-folds. They use only a guide track and that
    can be driven over w/o issue
  8. TCT
    TCT Formula Junior
    Mar 9, 2004
    873
    #58 TCT, Jan 16, 2006
  9. TCT
    TCT Formula Junior
    Mar 9, 2004
    873
    #59 TCT, Jan 16, 2006
  10. ghost
    ghost F1 World Champ
    Dec 10, 2003
    10,046
    Singapore
    Good lord Steve. Unbelievable.
  11. BMW.SauberF1Team
    BMW.SauberF1Team F1 World Champ
    Dec 4, 2004
    14,560
    FL
    That looks awesome! What's that car on the right side of the picture? Is it an F1 nose cone by itself; I don't see a car suspension. Please post more pics!
  12. Challenge64
    6,367
    Ron
    yea that is just the nosecone :(
  13. Ronbo
    Ronbo Formula Junior
    Aug 2, 2005
    413
    Morris County, NJ
    Ron
    Assuming you have a central station security system, make sure you add fire and burg zones for the garage.
    BTW, I am totally envious of these garages. I know I'll never have one. Where I live it would take (literally) years of permit wars and so much money that it wouldn't be make sense to try. If (when!) I outgrow the garage at my house I'll have to go for an "off-campus" warehouse rental.
  14. mhm4223
    mhm4223 Rookie
    Nov 14, 2004
    12
    Perrineville, MJ
    Michael Merkin
    I have just finished an addition to my garage which adds another 2 bays for storage. I currently have 2 dual post above ground lifts, heat and a/c, commercial air compressor, hot and cold running water, overhead lighting, complete fire protection and alarm system, and a drainage system for the water run off. The new addition includes a flush mounted 4 post drive up 9,000 lb. lift. I designed it to be flush mounted to avoid any additional labor to get my 360 Challenge up in the air. The side post lifts are tough to get a low ground clearance vehicles in the air. If you use a 4 post drive up, make sure you include a jack support to give you the flexibility to work on the suspension and the wheels. Make sure you include many outlets, 220 supplies, and use retractable reals for your air lines, water lines, etc. Make sure you include heat and a/c to control your climate. Extremely important for quality car care. Also use a good quality epoxy floor covering since it will resist any problems caused by abrasive chemicals. The only thing I have not mastered is the correct lighting. Flourecent lights provide a glare and make it difficult to detail a vehicle. Also make sure you have good ventilation if you want the option to run your vehicles while inside. Leave enough room in the front of your lift area to build or install a good quality work bench with a steel deck so you can have a good work area. You need to make sure your floor base is strong enough to support a lift. I used an archetect to design a garage with the proper height, for the lifts, and the correct concrete for support. I also prewired the walls for stereo. Make sure you leave enough clearance for the garage doors not to interfere with the lift when raised in the up position. It is very easy to make mistakes without the proper planning. Hope this information is of some help in designing the ultimate "functioning" garage.
