BUILDING RACE 308 ENGINE..ANY IDEAS? | FerrariChat
Discussion in '308/328' started by chevalcabre, Dec 5, 2004.
  1. chevalcabre
    chevalcabre Formula Junior
    Nov 2, 2003
    893
    Montreal
    Steve Maman
    I HAVE A DRY SUMP MOTOR GOING INTO A RACE JIM CARPENTER 308 GTO ....BUILT WITH ALL RACING BRAKES,SUPENSION..INCREDIBLE CAR...
    I DONT WANT TO SPEND BIG $ AND WANT TO LEAVE IT RELIABLE...
    I THOUGHT OF JE PISTONS,PORTING THE HEADS.... WOULD THAT DO ANY GOOD OR MAY I LEAVE IT ORIIGNAL AND USE THE 250 HP ALONE....??
  2. fatbillybob
    Aug 10, 2002
    29,004
    socal
    If this was a Jim Carp 308 racecar you have the wrong goals for the wrong car unless you want a slow racecar. If the chassis that Jim did is very good with compromises set up for racing then IMO you need to spend the money to have the engine done right. If you can't do it yourself and do no have the tools send it to a guy like Dave at Cavallino Ramparte Boulder Colo.. See the thread under the super ferraris section the thread " F40 Engine Rebuild - Don't try this at home!" if you want to do your engine right vs. cheap. Cheap gets you cheap if cheap is what you want.
  3. jharkercfduc
    jharkercfduc Karting
    Sep 4, 2004
    133
    riverside california
    jonathan harker
    is that the black 288 bodied 308 that was for sale in canada with the motor out? either way, norwood turbo with upgraded components would make the most of the motor. you can pick the level of hp/reliability with the boost level and component quality.
  4. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    I think one also needs to look at the rules of the classification you want to race in, as there are restrictions or re-classifications of modified or blown cars. For sheer horsepower, most bang for buck is with forced induction, though. Need to somewhat design to the class in which you will be competing.
    Can't go wrong with a call to Carobu or Norwood's.
    Good luck!
    rt
  5. chevalcabre
    Nov 2, 2003
    893
    Montreal
    Steve Maman
    I GUESS STOCK,SOLID RELIABLE IS BEST.I AM NOT GOING TO BE A WINNER,JUST FOR FUN TRACK TIME AND ENJOY A CHEAP NICE CAR...
  6. Auraraptor
    Auraraptor F1 World Champ
    Sep 25, 2002
    13,972
    MO
    Omar
    Steve, I suggest updating the cooling system, as well as adding trany cooler and if I recall a diff. cooler as well.
  7. pma1010
    pma1010 F1 Rookie
    Jul 21, 2002
    2,559
    Chicago
    Philip
    Steve
    When ever you start modifying the engine you are going to start spending money at a pretty good clip. I'd recommend you talk to James Patterson at Norwood or Mike at QV in London.
    Cams are probably biggest bang for the buck.
    RPM is one of the biggest determinants of reliability.
    Philip
  8. johnbob
    johnbob Karting
    Nov 8, 2003
    124
    Oklahoma
    Norwood Twin Turbo, no question. 288 was a turbo car, biggest bang for the buck- with great reliability and driveability if you are reasonable with the boost.
  9. Auraraptor
    Sep 25, 2002
    13,972
    MO
    Omar
    Actually, I would venture the best (as well as a way of INCREASING reliablity) bang for your buck is a modern fuel injection system. You can add around 30 hp with this.
  10. Jagbuff
    Jagbuff Formula 3
    Jan 13, 2004
    2,267
    Site of US F1 Race!
    Franck
    If you are building a race 308 engine, there is no way to do it for cheap. If you are looking for reliability and keep the cost down there is no way you can increase horsepower. The twin turbo option - if done right - will probably set you back at least $35K if the engine is in good shape which is a fair chunk of change. It will probably not be the best for racing, however; if will be a blast to drive...
    Do you have pictures of the car? Does it have the correct GTO engine orientation?
    Franck
