For Sale - Bulk lot of 348 engine and other misc Ferrari parts | FerrariChat
For Sale Bulk lot of 348 engine and other misc Ferrari parts
Discussion in 'Ferrari Parts & Collectibles' started by Speedmade, Feb 1, 2024.
  1. Speedmade
    Speedmade Formula Junior
    387
    Minneapolis, MN
    Reed H
    I am trying to purge the last of all my Ferrari parts from my garage. I mostly focused on 348 motor stuff but have a mish-mash of other parts. I will not sell anything separately. This is being sold as a package deal. Would prefer pick-up from my location. But I will package and crate at as minimal expense to buyer as possible. Shipping charges and logistics would be the buyer’s responsibility.
    $7000
    I will provide pictures to serious inquiries only. Trying to minimize scammers on other platforms.
    Reed Herman
    Used 348 parts
    348 block w/head studs, all good liners, timing cover and parts, oil pan
    348 block w/head studs, all good liners, no timing cover or pan
    348 block w/head studs, some bad liners, timing cover and parts, oil pan
    348 complete oil pump assy w/ windage tray, pickup, etc - Qty 2
    348 crankshaft - magnafluxed and micro-polished - std journals - Qty 2
    348 crankshaft - excellent used. Still in block
    348 cylinder heads bare with cam caps - need rebuild - pair
    348 camshafts - full set of 4 - Qty 2
    348 crank sensors - Qty 2
    308/328/348 complete water manifold assy - Qty 2
    308/328/348 "L" rods - Qty 8
    308/328/348 "F" rods - Qty 4
    308/328/348 "G" rods - Qty 4
    308/328/348 cam cover end cap - Qty 2
    348 alternator bracket set
    348 valve cover pair
    348 pistons, rings, pins, clips (green dot clearance) - Qty 15
    348 timing belt idler set
    348 cam seal retainers - modified to service bulletin - Qty 8
    348 complete water pump assy
    348 water pump
    348/355 engine stand mount tool - side
    348/355 engine stand mount tool - rear
    348 motor mount casting
    348 Mondial T power steering pump assembly
    348 Camshaft sensor assembly - broken plug, sensor good
    348 Throttle bodies - pair
    348 cam pulleys upper - used
    348 valve retainers and locks - Qty 32
    308/328/348 valve buckets and shims - Qty 32
    348 exhaust valves - Qty 16
    New parts
    348 factory Denso alternator upgrade kit - alt, brackets, idler, belt, harness
    348 oil pump chain
    348 timing chain
    348 OEM head gaskets
    QV/348 copper exhaust gaskets
    348 oil filter
    348 valve cover gasket set
    Ferrari wheel valve stems - Qty 8
    365 BBi wiper motor assembly
    348 cam pulleys upper - welded and plated - Qty 8
    348 cam pulley lower- welded and plated - Qty 2
    348 crank damper/pulley - plated
    Other Used Ferrari parts
    355 motor mount casting
    Lancia Thema 3.2 intake assy
    308/328 QV engine stay
    308/328 breather cam cover cap
    QV head castings - mock up
    308/328 QV valve covers - pair
    Crancase vent valve - 365
    308QV intake valves - used
    308 differential cover
    308 2V cam end cap - Qty 2
    308 2V distrib mount plate - Qty 2
    328 E brake lever - leather
    355 crank timing gear
    355 oil pressure sensor
    400 door handle seals
    308 speedo sensor
    328 speedo sensor
    308 trans pins/springs/balls
    355 cam sensor holder
    308/328 dash HVAC levers and badges - Qty 2
    Pile of other Fiat, Ferrari, switches, gauges, etc
