Buying a 458 and I need your help! | FerrariChat
Discussion in '458 Italia/488/F8' started by da1828, Jun 8, 2024.
Tags:
  1. da1828
    da1828 Rookie
    Jun 6, 2024
    1
    dada
    I'm planning on buying a 458 spider but after a full checkup, the checkup specialist found an oil leak and also this Vehicle diagnostic report sounds kinda bad
    The car has 66k kilometers, 2014, and maintained with ferrari, price is around 3/5k€ under market price
    Just a quick explain: It's my first supercar, and I know a ferrari is very expensive to maintain, and I'm perfectly fine with that. But, I would rather spend money on maintaining a car because I used it, rather than paying for the previous guy who owned it.
    I need a ferrari owner to tell me if any of this is considered a "serious issue", by serious issue I mean costly (or very costly) potential problem or if it's just a detail.
    The car was in a showroom for a while so I think battery is low and therefore the electronical reporting can be "glitched" and the oil leak is weird as I don't see anything under the car, looks like a minor leak
    Do you see anything alarming ? Anything that should be a deal breaker ?
  2. mikey64
    mikey64 Formula Junior
    567
    TN
    mikey
    I agree all those electrical issues could easily be a bad battery. Many specifically state comms issue or voltage issue. The selling dealer should install a quality new battery like Optima yellow top, fully charge it before install and then reset the codes and see if any return.
    The “oil leak” looks like a somewhat normal amount of attracted dirt and I don’t see anything too concerning. A dirty engine is often a happy engine. Do you see any wet or pooling oil anywhere?
    Have the dealer remove all of the bottom panels so that you can see from the underside.
    Personally I wouldn’t give up on this one just yet but I’m also my own mechanic. Things get relatively expensive quickly when you have to rely upon others to maintain a Ferrari.
    Where are you located and where is this car? Maybe a member can further assist or advise on reputation of the seller.
  3. Kent Adams
    Kent Adams F1 Rookie
    3,238
    No, don't use those Optima batteries. They are not the same company they were years ago. If you want an ADM, use a different battery, Interstate in the US. That's a lot of oil in my opinion and the last thing you want is a head gasket leak. Do a compression and leak test on the engine. Check the brakes and rotors.
    Any gearbox codes that happen needs further investigation. Ask yourself this, would it cost the same to fix all these things + the price of the car than spending more for a lower mileage car without these codes? If so, then it's a hard pass.
    luvair likes this.
  4. luvair
    luvair Formula 3
    1,593
    I question, if only 3/5k€ under market. If a dealer is to sell, why even have a bad battery that raises error codes. Becomes a guessing game.
    To me, it’s difficult to do analysis without more info. Be interesting for you to check all service records. If they are none or very few available, I would pass. If available, I would want a reputable Ferrari shop to specifically advise the actually source/part that is leaking.
    A thorough PPI with leak down, may cost you over 2 hours labor. A new battery, is not inexpensive either if installed by shop / dealer.
  5. Is it from a Ferrari dealer?
    Just from what you've said, I would pass on this 458. Whatever dealer has been selling that car has not maintained it well.
    As always, buy the seller, not just the car.
    luvair likes this.
  6. Mrpseudonym
    Mrpseudonym Formula Junior
    602
    Sydney, Australia
    I too would pass. While it is likely that many of those errors are simply the battery the open circuit on the entertainment system may not be, but with 66k kms I’d want it to be an absolute steal, and it isn’t. Particularly as it is your first Ferrari, you want the experience to be magical and unforgettable (in a good way). Hold out for a better one.
    mdrums likes this.
  7. PGH
    PGH Karting
    Aug 3, 2022
    87
    Arizona
    Paul Hobeich
    I would pass, too many “red flags”. I bought my first Ferrari and it started similar, 15k later and issues were resolved. Thankfully I negotiated it in the price and expected the cost. Good luck
  8. mdrums
    mdrums F1 Rookie
    Jun 11, 2006
    3,431
    Tampa FL
    That engine area is filthy!!!
    Too many fault codes then an oil leak….at that price NO…on this one…keep looking
    430jm likes this.
