Buzzing sound driving me nuts | FerrariChat
Discussion in '308/328' started by Tim3rdsf, Dec 13, 2006.
  1. Tim3rdsf
    Tim3rdsf Rookie
    Dec 6, 2006
    46
    Watkins
    Tim
    There is a buzzing sound coming out of my dash it is not the door buzzer. I think it is a seat belt buzzer. It does not does not go away when the belts are connected. It is not a real loud buzz and changes in pitch . Can I unhook it or can anyone tell me how to fix it?
  2. Rachane
    Rachane Formula 3
    Sep 5, 2005
    1,086
    San Francisco, CA
    Rachane
    1. What model of car?
    2. What does the buzz sound like?
    3. Where in the dash is it coming from?
    4. Happen when key is on, or only when engine is on? Only when moving?
    5. Anything else to narrow it down?
  3. Dino2010
    Dino2010 F1 Rookie
    4,852
    Belgium
    From time to time I have in my 328 also some unlocatable buzzing! Mostly some place under the dash! I just slam it a little, gone! A week later there it is again! Slam it again! Nothing for a month! Don' t forget , this is Italian stuff from the 80's, they used be a bit sloppy with wires, cables, ... Don't worry, it has it's charm! Regards!
  4. Tim3rdsf
    Tim3rdsf Rookie
    Dec 6, 2006
    46
    Watkins
    Tim
    It is a 1983 308 GTSi Euro model. Sounds like it is coming from the drivers side of the dash. It is not as loud as the door ajar buzzer. And it only happens when key is in the ignition, and running. It does vary in pitch and sometime goes away when clutch is engaged , like at a stoplight.
  5. Tim3rdsf
    Tim3rdsf Rookie
    Dec 6, 2006
    46
    Watkins
    Tim
    I unhooked the door ajar buzzer and now can hear where the sound is coming from. It is under the seat drivers side. Does that help.
  6. Tim3rdsf
    Tim3rdsf Rookie
    Dec 6, 2006
    46
    Watkins
    Tim
    It is coming from a box that says Jetronic on it a 6" by 6" box that if I wiggle the wires I can alter the sound does that help.
  7. Steve Magnusson
    26,970
    #7 Steve Magnusson, Dec 14, 2006
    Can you describe your configuration further -- is it a 2-valve or 4-valve (QV) engine?
    Has it been somehow "converted for the US"?
    Yours is the first mention that I can recall of anything "Jetronic" (i.e. Bosch CIS related) mounted under the seats in the passenger cabin. Your description matches the injection ECU illustration given in the OM for an '84-'85 US version 308QV (K-Jet with Lambda), but it's mounted in the trunk of that model. (An ecu driving a lambda frequency valve might buzz a little as the current switches.)
  8. Tim3rdsf
    Tim3rdsf Rookie
    Dec 6, 2006
    46
    Watkins
    Tim
    It is a 4 valve that is the box but it is not in the trunk it is under the seat that is all I know
  9. Steve Magnusson
    26,970
    #9 Steve Magnusson, Dec 14, 2006
    You might compare your system to the injection system figures shown in the respective OMs. If you've got items G & D (as shown in the '84-'85 US version figure) in your system, you can't just unplug that offending ecu -- you'll have to move it into the rear trunk so you can't hear it ;)
  10. Tim3rdsf
    Tim3rdsf Rookie
    Dec 6, 2006
    46
    Watkins
    Tim
    what does G & D attach to? I looked at it just now and it liiks like it might have that G part it is near the air box. It looks like a solinoid of some sort with a couple of wires coming out of it.
  11. Steve Magnusson
    26,970
    Item G is a passive (pulsation damping) device and only has "in" and "out" fuel line connections.
    Item D (the metering valve, A.K.A. frequency valve, A.K.A. Lambda valve) has both "in" and "out" fuel line connections and a 2-pin electrical connector.
    The fuel line path (on the stock '84-'85 US 308QV) is:
    metering head (supply port) -to- Item D -to- Item G -to- metering head (control port)
