Buzzing sound when turning igniton 360 | FerrariChat
Discussion in '360/430' started by Toolie, Jul 24, 2014.
  1. Toolie
    Toolie Karting
    Jan 15, 2013
    210
    Houston,TX
    Recently I've been getting a buzzing sound turning the key before starting. What can cause this?
  2. vrsurgeon
    vrsurgeon F1 World Champ
    16,528
    Charleston, SC
    Curt
    Door open? Closed?
    Could be a short somewhere. Where is it coming from?
  3. Toolie
    Toolie Karting
    Jan 15, 2013
    210
    Houston,TX
    #3 Toolie, Jul 25, 2014
    Curt,
    Please see youtube link for the sound. I did some test, it happens when the headlamp switch is ON position. When I turn it to off position buzzing goes away. Is this Normal
    YouTube
  4. vrsurgeon
    16,528
    Charleston, SC
    Curt
    Video isn't showing when I click on it.. perhaps embed on FChat.. ?
  5. Toolie
    Toolie Karting
    Jan 15, 2013
    210
    Houston,TX
    oops it was private. It should work now. Also both of my dome lights are not working correctly. Sometimes they work.
  6. vrsurgeon
    16,528
    Charleston, SC
    Curt
    Just listened.. don't think that's normal to my ears.
    For the dome lights check the fuse and clean it off. It's linked to the stereo system as well. If the fuse to the dome light is OK, then switch on the door might be wonky or the bulb in the light itself. Is it the light that comes on with the door open or the reading lights? in some cases IIRC the switches in the light assembly also get funky.
    I'm wondering if you have an electrical draw that's too great or current over a circuit that isn't enough and you're getting funkiness going on. It's diagnosis and fixin' one thing at a time.
  7. Toolie
    Toolie Karting
    Jan 15, 2013
    210
    Houston,TX
    Dome light comes on when doors open, but it has a delay. map light does not turn on. I will have to check the fuse.
  8. tr512
    tr512 Formula 3
    Apr 12, 2007
    1,600
    canada burnaby bc
    Michael
    Check your door switch.I had the same problem and beep on my 355f1, and my F1 light stayed on but the pump still primed. but i could not shift into gear.
