430 - Buzzing | FerrariChat
430 Buzzing
Discussion in '360/430' started by flyboy, May 17, 2022.
  1. flyboy
    flyboy Rookie
    Jul 18, 2008
    41
    Ludington Michigan
    Les Kaines
    I have a recently purchased F430 that randomly has a harsh buzzer. Occurred at both low and high speed 15 to 60 mph sometimes has a voice that sounds like slow down even when going 10mph. Can occur soon after start up and after driving for 20 minutes. No warnings on the annunciation panel.
  2. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    First off have a look at the tail pipe ends, might need a spot weld. Also drop the diffuser and check the exhaust brackets fixed to the rear of the gearbox. They can break- they support the exhaust with U clamps bolted to the gearbox, you might want to throw them away as will run without them
  3. CoreyNJ
    CoreyNJ Formula 3 Silver Subscribed
    Apr 17, 2006
    2,462
    New Jersey Shore
    Can also be the springs on the catalytic converter flange bolts. They can buzz a little at very odd times. if you are overly sensitive maybe that's what you hear? I brought my car to my mechanic because I thought something was wrong and he said they all make intermittent noise but most people don't even notice it over all the other noises in the car. I chalk it up to my OCD.
  4. boba fett
    boba fett Formula 3 Silver Subscribed
    Feb 24, 2019
    1,122
    England UK
    I had this as well, I looked everywhere and it turned out to be the wife!
    SoftwareDrone and EastMemphis like this.
  5. Qavion
    Qavion F1 World Champ Silver Subscribed
    Feb 20, 2015
    14,292
    Ian Riddell
    Seems odd that there are no warning lights and that the speeds are so random. I would assume that, say, a passenger seat belt warning would generate a light(?) and would be more speed specific.
    There is an option on Gulf (Arab) cars which sounds a buzzer at a higher speeds (120kph?), but I wasn’t aware it produced an aural (voice) warning.
    Broken aftermarket radar detector?
    Gearbox overheat warning malfunction?
    Possibly an issue with the logic in the instrument cluster. Have you tried a battery reset?
  6. MJGinTX
    MJGinTX Karting
    Mar 30, 2019
    161
    Indianapolis, IN
    Could it be a radar detector?
  7. CoreyNJ
    Apr 17, 2006
    2,462
    New Jersey Shore
    Wait did the OP saying it was talking to him saying “slow down”? Must be an old radar
    Detector built in that is getting false alarms.
  8. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    Buy a loud exhaust and it will go away
  9. SoftwareDrone
    SoftwareDrone F1 Veteran Sponsor Owner
    Jan 19, 2004
    7,860
    San Jose, California
    I tried that. The wife is still here...
  10. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    Yes and she owns 1/2 of the exhaust plus bits of the car
    LorenzoR likes this.
  11. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    Would this then be considered "buzzed" driving while operating the vehicle!!!
  12. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,933
    Central NJ
    Dominick
    To close this thread ..after speaking to flyboy .. it does seem like a hidden radar detector .. he will look for it ..must be under dash or in ash tray
    Qavion likes this.
