Bypass Valve Opening Late? | FerrariChat
Discussion in '348/355' started by sgtpeper, Jun 16, 2020.
  1. sgtpeper
    sgtpeper Formula Junior
    May 4, 2004
    426
    Denver
    Jeff
    I took my car over to Maranello Motors today just to get another clean bill of health - everything looks great all around.
    However, my car has a Forza control for the bypass valve. We hooked a T into the vacuum line and were able to see that the control module works to open and close the valve. When I start off in 1st the valve opens properly at a low RPM. However, in 2nd and above, it doesn't seem to want to open until later - 5-6k or so - even with my foot to the floor.
    Any ideas what could be causing that?
    Thanks!
  2. Kokose7en
    Kokose7en Karting
    Dec 5, 2019
    209
    SF Bay Area
    Sounds normal, only 2nd gear for F355 actuates later in the RPM range. Every other gear is earlier
  3. sgtpeper
    May 4, 2004
    426
    Denver
    Jeff
    Interestingly enough, I drove home with the bypass valve just open and now I have a code - p1448
  4. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Bummer, I'm not a 355 guy but I have read about Thermocouple and TCU with that code.
  5. bcar1
    bcar1 Karting
    Aug 2, 2017
    224
    NYC
    Bob
    I think that is expected- p1448 means the bypass thermocouple is experiencing heat when it thinks the valve should be closed, or not experiencing heat when it thinks the valve should be open.
    I also believe the bypass behavior sounds normal- it opens around 4500 rpm for me in all gears except 2nd where it opens at closer to 6500. There’s a post somewhere here where someone actually read the LUT from the ecu and noted what it was.
    MAD828 likes this.
  6. sgtpeper
    May 4, 2004
    426
    Denver
    Jeff
    So do you think having the Forza controller in full open caused it? I reset the code and I'm hoping it doesn't come back. I have to go through emissions testing soon to register the car so I'm hoping it stay off.
  7. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,629
    Elliott Caras
    100% that’s what caused it.
  8. sgtpeper
    May 4, 2004
    426
    Denver
    Jeff
    Well, then I will keep it in the "A" mode ha.
  9. Qavion
    Qavion F1 World Champ
    14,272
    Ian Riddell
    Here are the official values for the 2.7 car.
    Is the 5.2 different?
    The main function (or perhaps even the only function) of the bypass valve thermocouple is to detect when the valve is open or closed when it is not supposed to be. Since the Motronics ECU is basing its own "valve open" command on engine rpms, throttle position, etc, I can't see how the Forza system can fool the Motronics ECU into thinking that the rpm, throttle, etc, have the appropriate values for the valve to be "just open" for your drive home.
    Does the Forza system have any documentation on this?
    Kokose7en, tres55 and 308 GTB like this.
  10. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,629
    Elliott Caras
    It does not have this function, it simply bypasses the oem trigger and keeps it open. Hence the check engine light.
    308 GTB likes this.
  11. sgtpeper
    May 4, 2004
    426
    Denver
    Jeff
    So why would anyone really want this then? I hate check engine lights so I'm not sure why I would really use this that much.
  12. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,629
    Elliott Caras
    The 2.7 cars do not have a thermocouple at the bypass junction so you can use this controller with no ill effect. I personally don't like the controller as it is designed that way for a reason and feels more responsive with the system working as intended.
    Qavion likes this.
  13. sgtpeper
    May 4, 2004
    426
    Denver
    Jeff
    What do I do to get rid of it?
  14. tres55
    tres55 F1 Rookie
    3,572
    Canada
    Reverse the install instructions.
    I had it on my 355. I also had a bluetooth BlueDriver OBD2 scanner for clearing the inevitable CEL on the go via my cell phone...but sometimes I just wanted it straight open for some spirited driving. :D
    Qavion likes this.
  15. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,017
    NE FL
    Ken
    Simply remove the thermocoupler, cap the hole and the code will not come back. The probes sole purpose is to taddle to the ECU when the valve is open to long.
    I have the capristo valve controller in mine
  16. Qavion
    14,272
    Ian Riddell
    So you're saying it won't flag a message if the valve doesn't open on your '99 US car?
  17. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,017
    NE FL
    Ken
    Affirmative, it provides no fuel trim no spark advance nothing related to the engine. It just simply is there to sense if the valve gets stuck open. Leave it connected, but just zip tie it away and cap the bung
  18. Qavion
    14,272
    Ian Riddell
    If you get no stored message or CEL, with your configuration, then that would seem to prove it. We've had so many (reputable) experts saying otherwise, it's hard to know who to believe. Seems like a bad design if that's how it works.
  19. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,017
    NE FL
    Ken
    They're many post with claims either way from people who have speculated but have never actually tried it.
    The few Ive found with actual experience have all posted no bypas related cel with the sensor removed. heres one from Goth in post #7 by a user in post #14 https://www.ferrarichat.com/forum/threads/hyperflow-capristo-installation-and-question.165071/#post-137020196
    also here in post #3 https://www.ferrarichat.com/forum/threads/bypass-valve-removed-slowdown-light.243098/#post-138648061
    Qavion likes this.
  20. Qavion
    14,272
    Ian Riddell
    Convinced. Thanks.
    I'm trying to remember the codes I got for having the Right cat SDECU and Exhaust Bypass SDECU plugs swapped over. There was at least one code for the main cat. The main cat temperatures are probably compared and see one cat cold (at least with the bypass valve closed). This is with new cats installed and a Goth Bypass valve fitted. But, as you say, cold bypass thermocouples are not flagged.
  21. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,219
    CT
    John Kreskovsky
    Wait a minute. That post #3 from above says;
  22. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,017
    NE FL
    Ken
    I had a few threads bookmarked regarding this and I quickly posted an example here, I guess i referenced the wrong post on that thread. Later there is mentioned of someone else with success.
  23. sgtpeper
    May 4, 2004
    426
    Denver
    Jeff
    But the moral of the story is I can leave the forza controller and just not hit the "B" button that leaves the bypass valve open all the time and then avoid the check engine light, correct?
  24. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,017
    NE FL
    Ken
    Considering it's completely free to try. Why not? Go to Home Depot and buy a 1/4-in or 3/8-in NPT brass cap (can't remember the exact size but it's one of those) zip tie the sensor away so it's not dangling. Reset the code, see if the 1448 comes back
  25. WATSON
    23,680
    WI
    That chart varies slightly for the 355 5.2 cars. The bypass valve operation is not only gear and RPM specific, but also monitors throttle position.
    I have that data at home somewhere and will dig it up when I can.
    The bypass theromcouple is looking for heat when the bypass is supposed to be open and no heat when it is supposed to be closed.
    If you remove the thermocouple from the exhaust stream, you will still get a CEL and 1448 code.
    If you wire the bypass valve open you will also get the 1448 code.
    If you open the bypass valve when the ECU thinks it should be closed you wil get a 1448 code.
    As far as I know, people that run with open bypass valves just pull the CEL bulb.
    There is a theory (real or perceived is up to you) about exhaust back flow and damaged headers running with an always open bypass valve.
    In response to your slow opening valve, check the solenoid supplying the vacuum from the air pump in the back. If that leaks it doesn't engage correctly and does not supply proper vacuum to open the bypass valve.
