bypass valve | FerrariChat
bypass valve
Discussion in '348/355' started by markcoznottz, Jun 18, 2008.
  1. markcoznottz
    markcoznottz Rookie
    Jan 29, 2005
    43
    england
    What are the pros/Cons of permanently wiring the bypass valve open on a 355?. I was wondering why some people worry so much about the valve rattling and if this could be a 'cheap' fix? How does the car drive differently with the valve always open? Would it lack bottom end torque?. Obviously it would be louder throughout the rpm range, but the valve opens anyway at a certian rpm so maybe thats not so important?. Iv heard several people refer to the exhaust valve sytem as being in place to boost low speed torque, but I seem to remember the exhaust system being designed as it is to pass drive by noise regulations at the time.
  2. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    If you have a 1995 it should not be a problem. On a 1996-1999 it will affect what the o2 sensors see and would get numerous ECU error codes quite quickly.
  3. Baptist
    Baptist Karting
    Mar 2, 2008
    78
    Mine is a 5.2 and it really didnt like the valve being wired open, it also screws with setting that the ECU makes during idle (my dealer hooked it up to SD1 and showed me the values were all over the place).
    It was put there for a reason, and i personally like the sound as the valve opens.
  4. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,326
    Palos Verdes
    Vince V
    Hey aren't you working on a "work-around" to this?
  5. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,958
    MD and NE
    Robbie
    Capristo has a way around it...
  6. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    #6 gothspeed, Jun 18, 2008
    Yes .............. very different than what is currently out there ...... and of course it will be keeping that renowned F1 sound ....... :)
    Yes I believe the 'y-pipe delete' version works well HP wise ........... but it kills the 355 F1 sound, I heard it on youtube and it sounds worse than a bone stock 360 IMO :( ........... and at that monster price ............. well .......... :rolleyes: ........... you be the judge .......
    http://www.youtube.com/watch?v=N8A-W_WqEe0
  7. Vegas-Guy
    Vegas-Guy Formula 3
    Nov 25, 2007
    1,828
    Austin, TX
    Reg
    Wow! that is bad....:( didn't even sound like a 355!
  8. 285ferrari
    Sponsor
    Sep 11, 2004
    20,958
    MD and NE
    Robbie
    I agree that sounds--not good!! but it was also videoed from inside the car--Would like to hear it as a fly by!!
  9. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    #9 gothspeed, Jun 18, 2008
    Robbie........ it sounds terrible IMO it lost all the high pitch F1 sound .... :( ........... it would be a lot easier for me to buy an exhaust than to make an exhaust that has what I want.
    Most aftermarket f-car exhausts now focus on shiny, pretty with lots of 'look at me' factor. For me its all about function and sound........ then throw in a satin or nero finish instead of the glamorous 'Liberace' look.... :eek:. The standard cappy sounds much better but does not flow as well as the new one. So that does not leave me many choices.... :(
    Here is what a good 355 F1 sound exhaust should sound like from 'inside' the car:
    http://www.youtube.com/watch?v=LbP2cPL41CM
    Here is the new cappy sound from the outside (even stock 355 sounds better IMO... :( ):
    http://www.youtube.com/watch?v=dNUmYXDRUFQ
    but hey ....... we make our own choices........ :)
