There seems to be some electrical gremlins and i just can't understand why one of the previous owner did this change or to what purpose. The lights in the front bumper is connected to a relay with an on/off switch where you can switch between power from either the relay box in front compartment or from another power source connected to one of the circuits at the fuses on the other side of the compartment.. I just can't understand what's the reason for this as if you switch it on the lights will be constantly on in the bumper and if the switch is off the lights will work as normal. Any clue about this?
Do you mean the fog/daytime flashers? Maybe the previous owner thought it was mandatory in Sweden to have daylight running lights? Bilar från årsmodell 2009 kan vara utrustade med så kallad DRL (Daytime Running Light, varselljus). DRL ersätter halvljus utan att belysningen bak är tänd. Notera att om ett släpfordon kopplas till en bil med DRL ska baklyktorna på släpfordonet lysa
