Cabin Heater Controls | FerrariChat
Discussion in '308/328' started by malh001, Jan 17, 2013.
  1. malh001
    malh001 Rookie
    Jun 10, 2007
    35
    Can anyone let me know what the letters D E F stand for on the cabin slider controls?
    I'm assuming D= demist and F = floor but E?
    Cheers
  2. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,664
    South East
    Jimmie
    Nothing : I'd always thought defrost or defog but the handbook doesn't help either
  3. vaccarella
    vaccarella Formula 3
    Apr 16, 2011
    2,291
    Paul
    This has occasionally intrigued me. I've seen it on other cars apart from the 308; same vintage and older (can't be sure if they were all Italian).
    Maybe E is Even or Equal, because it distributes the same output to upper and lower diffusers ?
  4. malh001
    malh001 Rookie
    Jun 10, 2007
    35
    Equal sounds plausible.
    I've tried adjusting it with the fan full on to see if it alters the flow from different vents, but it doesn't,t seem to make a noticeable difference.
  5. greyboxer
    Dec 8, 2004
    12,664
    South East
    Jimmie
    I think you're over-thinking this - it works just as the manual describes it :
    When the lever points at zero the vents are closed - when the lever points at the up arrow the upper vents are open - when the lever is in the middle and points up & down the vent facing down under the dash is also open
    Your down facing vent also has a built-in flap - are you sure its open ?
  6. malh001
    malh001 Rookie
    Jun 10, 2007
    35
    Yes, that would make sense. As for DEF, a bit of googling suggests its short for Defrost?
  7. vaccarella
    Apr 16, 2011
    2,291
    Paul
    Well yes, but only if it labels one setting. Defrost / Demist.
    But on the 308, the D, E and F indicate three separate things.
  8. DGS
    DGS Seven Time F1 World Champ
    71,751
    MidTN
    DGS
    I'd guess they're abbreviations for settings in Italian.
  9. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,217
    CT
    John Kreskovsky
    Wait. I have to go out in the garage and get a hammer to hit myself in the head with.
    Try a little common sense here.
  10. godabitibi
    godabitibi F1 Veteran
    Jan 11, 2012
    6,329
    Papineauville, Quebec
    Claude Laforest
    I allways tought the D meant defrost and the F meant floor, but never bother with the E. But yes Equal or equalize makes sense.
  11. FiatRN
    FiatRN Formula Junior
    Nov 21, 2008
    319
    Denver, CO
    Jonathan Drout
    #11 FiatRN, Jan 18, 2013
    Read The Ferrari's Manual
    The Dot is closed.
    The up.down arrow is a mix of foot/windscreen
    the up arrow is only windscreen vents.
    Think about how the system works physically - there is a flap door at the Y splint in the air passage. You can close the whole system off, or opening it in the middle, or close off the foot section. Cf the GT4 manual's drawing.
    -sorry - I can not get the proper orientation on my scan of the manual page, and I can not find a more "straight" on view of the ventilation controls from my car. I have lost the cable to connect my camera to my laptop (don't ask) and can't go take a new photo. Life is a mess, but there's still a GT4 in my garage!
  12. johnk...
    Jun 11, 2004
    11,217
    CT
    John Kreskovsky
    #12 johnk..., Jan 18, 2013
    Maybe this will help? Or you can look for some mystical interpretation of what Chevy meant by DEF and HOT back in '69. I wonder what F A N stand for?
    This thread is an attempt at humor, right? I mean no one seriously thinks DEF stands for anything but defrost, right? if you do, I have this bridge.....
  13. malh001
    malh001 Rookie
    Jun 10, 2007
    35
    Over here we usually call it demist rather than defrost. I thought it may have been abbreviations for something in Italian, now i know.
    I have an idea for what F A N my stand for, but you might not like it!
  14. vaccarella
    Apr 16, 2011
    2,291
    Paul
    John, the entire control does not defrost. Only the upper setting directs air to the screen. Following your logic, the DEF should only appear beside that upper setting. It doesn't.
