cabin temperature in my 456 | FerrariChat
Discussion in '456/550/575' started by 456GD, Jun 25, 2014.
  1. 456GD
    456GD Karting
    Nov 14, 2010
    143
    London, UK
    George
    Now that the weather is getting hot in the UK, the following problem became apparent. When I switch on the air condition hot air is flowing in the cabin. The aircon works just fine as a unit though.
    The problems seems to be a water valve which is attached to the firewall (right next to the battery) and regulates hot water into the cabin ventilation system. The valve seems to be sticky allowing too much hot water at all time.
    Anyone had similar issue?
    Does anyone know the part number?
  2. MotoMeccanica
    MotoMeccanica Formula Junior Silver Subscribed
    Aug 21, 2006
    450
    Canada
    I went through quite a bit to get my 456 AC sorted, similar symptoms. My first question is you say it works fine as a unit though.....can you explain this more?
    Do you know for sure that it is the hot water valve?
    Thanks,
    Scott
  3. 456GD
    456GD Karting
    Nov 14, 2010
    143
    London, UK
    George
    Yes, basically I had a friend who knows a things or two about it and he manually blocked the pipe that feeds the hot water through this water valve and amazingly a couple of minutes later the cabin was blowing with super-cold air.
  4. MotoMeccanica
    Aug 21, 2006
    450
    Canada
    Ok then, it will be different fix than mine.
    I'll have to let someone else chime in then.
    Scott
