Calculation | FerrariChat
Calculation
Discussion in '348/355' started by fxdwgs, Apr 26, 2007.
  1. fxdwgs
    fxdwgs Formula 3
    Aug 22, 2006
    1,016
    Sjobo, Sweden
    Bengt
    If you want to change from R12 to R134A how do you calculate or estimate how much gas you will need?
    The book says 975 g but that is R12 and as far as I can remember you should only fill up to 650g or so with R134a.
    Am I right or wrong?
    //B//
  2. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    Don't do it.
    R134 is less efficient. It requires larger evaporator and condensor coils to achieve what R12 did.
    So that tells you you will lose efficiency to backward convert the system.
    Gas volume would be about the same as R12.
    Big mistake. Don't do it!
  3. fxdwgs
    fxdwgs Formula 3
    Aug 22, 2006
    1,016
    Sjobo, Sweden
    Bengt
    Can´t get hold of the R12 here anymore.
    Like I wrote in another thread I have to go to Poland to get it done in that case and still sitting like a duck if they catch me.
    Got no choice as it looks like.
    //B//
  4. RS_america
    RS_america Rookie
    Mar 23, 2005
    29
    Moscow / Russia
    Alexander
    Hi
    I've had a same problem here in Moscow for my 911,
    Specialists said should not do it due to gas may destroy (corrosion ) old system. I dont know if it is valid only for 911 , but double check with specialists.
    I had to change complete system
    good luck
    A
  5. PAP 348
    Dec 10, 2005
    100,224
    Mount Isa, Australia
    Pap
    I just go off the head pressures, about 15-20 for the low and about 230-250 for the high ;)
    Don't forget to add a bit of oil also :)
